I just ordered a 2021 RST Z71 in shadow gray metallic. I’m having a little buyers remorse after seeing all the beautiful satin steel trucks in that post. Let’s see some of your shadow gray metallic ones!
This is my 20 Elevation. I traded in the RST for what I paid for it and I have to say I like this color a lot better. Looked at a Silverado in the same color but I stole this truck!
What color is the gmc?
5 minutes ago, Daggs said:
Satin steel metallic
Ok, yeah, I think so. I was t able to see one in person before ordering. Probably would have went with SS, but I’m sure I’ll be happy with mine. Hoping to do the red tow hooks, tint front windows to match rears, black Chevy on tailgate, possibly rims/tires with level kit, maybe some black emblems.
We were trying to decide between Satin Steel and Shadow Gray. Went by the dealership to see the colors in person first. We loved Shadow Gray and don’t regret it at all. We had a Wrangler that was Silver before this. Stain Steel was too close to that color.
I go back and forth with my decision all the time. Shadow gray is very nice but I think if I could do it over I'd go satin steel.
Mine came in....time to start looking at modifications ? I think it is growing on me. Needs some tires, rims and a level or 3” kit.
I thought that I wanted Satin Steel.  After owning this truck for 4 months I like this color better.
-Eli
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
