Hello,
I have a 2020 sierra Elevation with standard tailgate. I was wondering if I can replace it with a multi pro tailgate, if it'll just be a plug and play with my stock harness or what can i do to make it work. I have a local seller here selling it for $500 came from his denali. Thank you in advance
Even if it doesn't work on your truck, purchase it and you can turn around and sell it for double easily.
I do believe someone talked about this once and the tailgate is a different width? IIRC
Edited by eppieguy
  • 10 months later...
I really need a center section of the multipro tailgate. Preferably in satin steel metalic. Tailgate mysteriously went down while hauling a car trailer and when turning, tailgate got into the  tongue jack. Still works just makes my 2021 at4 look "not new"
You can't just add it. My dealer looked into it when they were trying to find a Trail Boss Custom with the MultiFlex tailgate. The box wiring harness is totally different for the tailgate and in order to add it would run about $3K.
That's likely with the cost of the tailgate at OEM prices.  I'd personally take Gangly's advice if it's the same color.
So I picked up a 2021 AT4 Multipro Tailgate in my trucks color for $600, bought the camera/buttons assembly and the non surroundview harness. He kept the camera/buttons assembly and harness to keep the surroundview working. I assembled and installed and the midgate does not function. Hearing that this might BCM programming issue. Anyone have any advice on a programmer that can turn the feature on?
  • 6 months later...
I just did a multi-pro swap for my 22 Silverado and it was relatively easy.  Luckily all of the wiring and relays were there for the minor gate.  For starters I cut the ground wire to the mid gate switch.  I needed to get 12V to this.  (I know I am talking ground and 12V, but stay with me here...)  At the Chassis side of the tailgate harness there is 12V Battery at Pin 1.  this was ran for trucks with the power up option.  My truck had the fuse and ckt already.  So I cut the lead out of the connector and ran a new wire up through the tailgate following the factor harness and connected it to the ground side of the pin on the minor gate switch.  The other end of the switch is the yellow lead that goes back to the BCM to signal the button was pressed.  Again I happen to have the minor gate relays and wiring on my standard gate LTZ, so I don't know what other trims it was also there. I needed to use this new 12V ckt I made to go direct to the two relays top drop the minor gate.  At the BCM I cut the Yellow switch wire (Pin X6-15) and connected it to relay outputs White/Gray (Pin X6-7) and Gray/Blue (Pin X7-7).  From the BCM this relay output was power to ground.  So by starting my switch at the 12V+ I just created a new ckt though the switch to the relays and down to GND.  I did pull the 30A endgate fuse while I was doing all this.  It all works!  The only downside is when the vehicle is locked, this ckt is still powered and will open upon press. I have the factory up fitter switches too, so I think I will use one of them as a disable possibly.  Should be really easy as the BCM is right below the upfitter switches.  The multipro I got was the same color truck but a GMC.  I still need to swap the emblems.  Waiting on a good sunny warm day to make that chore a little easier.
I KNEW IT.  I had a GM guy telling me at the Auto show that the GMC tailgates wouldn't physically fit on the Silverado, and that neither the GMC or Silverado adjustable tailgate would fit on a truck that didn't come from the factory with it.  I called BS and he couldn't tell me why.  Thanks for doing us all a service Sharpie.
The place there is a fit issue is 2500/3500 vs 1500.
The heights are different.
Yea I meant to mention that too.   All Chevy/GMCs for 2500/3500 are the same and all 1500's are the same, but NOT interchangeable.   Thanks Redwngr.  I'll also mention the only Bowtie that seemed to be for a HD Chevy w/ muli-flex was the black bowtie.  I ended up buying a 1500 gold bowtie and I'll stick that on.
So is yours you did the swap on a 1500 or a 2500/3500?
My Silverado is a 22 3500 Dually LTZ Trim. I guess I need to add that to my profile.
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
