Anyone running the 3d maxpider mats? I have the husky weatherbeaters and I like them but they keep slipping under my wires feet when she is getting in and out of the truck. These ones are supposed to hold in much better. I'm just wondering if anyone has tried them and would recommend? If you have any pictures that would be good.
https://www.amazon.com/3D-MAXpider-L1GM02501509-All-Weather-Chevrolet/dp/B07XBY8H82/ref=pd_lpo_263_t_2/141-7180560-4996968?_encoding=UTF8&pd_rd_i=B07XBY8H82&pd_rd_r=92c6de6a-2185-4307-a1f7-6fc0dac8fea9&pd_rd_w=CgKMD&pd_rd_wg=PdYJe&pf_rd_p=7b36d496-f366-4631-94d3-61b87b52511b&pf_rd_r=4BBFH2MDEPM1K66134AJ&psc=1&refRID=4BBFH2MDEPM1K66134AJ
I've seen these, but never ordered. I'd recommend Weather Tech Floorliners. Similar pricing and they have always worked great for me.
These are the Husky liner you want, they are thicker rubber with more grip. The Weather Tech liners will be just as slippery if not more slippery than the WeatherBeaters.
https://www.huskyliners.com/X-act-Contour-Floor-Mats/2020/chevrolet/silverado-1500/body-style/crew-cab-pickup/factory-storage-box/vehicle-has-carpeted-factory-storage-box
Also, the GM made mats are pretty good as well. I have them in my 2020 and had the Husky X-Act in my 2015 Silverado and 2019 Tahoe.
Edited by sclemmer
added info
I agree; I had the Husky X-act Contour liners in my "other" truck and I liked them a lot but they actually were not that durable so I put the GMC all-weather mats in my new Sierra and so far they are solid.
