Has anyone else noticed their trailer brakes feel weak on their 20 sierra 1500? Mine is a max Tow pkg with the 6.2
I tow a 8.5 x20 enclosed trailer tandem axles with dexter self adjusting brakes on both axles weighs about 5500-6K lbs  loaded. I used to tow that trailer with a V8 Grand Cherokee with an aftermarket brake controller and it stopped great, frequently felt like the trailer was stopping the jeep if the gain was much over 6. I have the gain set on the integrated controller in my truck at 10 and it feels like I have less braking power than I had on my Grand cherokee at a gain of 6-7.  I Towed my buddies trailer about the same weight but manually adjusted brakes from STL to Moab Utah and back and had to stop and adjust his brakes as I had almost no trailer brakes. He tows with a 2016 silverado  integrated brake controller and had to adjust the drum brakes back down as he had too much brake force when connected to his truck. Anyone experience something similar? Or advice on how to improve trailer braking power?
With the gain set to maximum when you use the manual brake at full detent you should see line voltage between pin 2 and pin 1.
Leave your gain set to maximum and have someone slowly push the brake pedal to the floor while you look at the multimeter. Somewhere before the bottom of the travel you should see line voltage between pin two and pin one.
If you are indeed seeing that and the braking force isn't sufficient then I think you need to look at your trailer brakes.
At work we have several vehicles with really crappy brake controllers that are time-based and not proportional based off pedal position.  Absolutely hate those because it chews up the trailer brakes.
A tekonsha P3 is a proportional brake controller that has an internal inertial sensor.  The harder it senses you applying the brakes the more braking it gives you on the trailer.  This also has a boost function if you want to apply even quicker.
Neither one of these features are available from the OEM.  Aside from sway control the only control the factory brake controller has over the trailer brakes to my knowledge is a proportional output based on your gain setting and the brake pedal position.
Edited by calgator73
Factory integrated brake controller does have output that is proportional to the braking level applied to the vehicle, and to the gain setting on the control.
I have more than one Dexter axle equipped enclosed trailer.  Mine are working fine with the factory controllers.
They are not used frequently, so each time I hook one up I plug/unplug the 7-pin several times to improve contact. I also drag the brakes lightly  when first pulling to polish of any surface corrosion.  The go thru the exercise of following recommended procedure for setting the correct gain for the current load.
Similar story with a larger and heavier loaded flat deck that was used much more often, but has now been sold. It was pulled with a 2011 2500 with ITBC. the enclosed ones have been behind several '11 and newer 1500 and 2500's.
Don't think I've ever needed to set one near maximum.
Make sure your brake wires aren’t chewy through at the axle. Happened to me on my trailer either it got tangled ona branch or maybe a chipmunk.
I did look at my trailer and the brake wiring and drums look good, Guess I am assuming the different brake feel is the difference between a controller that has inertia and proportional vs just proportional.
One other report of weak activation of brakes. Think that user took it back to dealer and found the connector back at trailer connector needed to be reseated
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
