Ive been noticing lately even if I shut my HVAC completely off it still blows air (hot or cold).  Whats the point of having a power off button if it doesnt even do anything?  It seemed to also dim up and down in intensity depending on throttle.  Anyone else doing this?  Also, it smells a little funny.  Almost a grease/must type of smell, not super pleasent.
2015 Silverado 23k miles
Edited by Zipsort
Have you tried to make sure the AC drain line is clear. Run a long tywrap up in it and give it a good push-pull-twist a few times to see if that will clear the drain. Trapped moisture can allow mildew to grow and cause some funky odors.
Thanks for the battery idea, however I dont think it would have anything to do with the HVAC fan blowing (decently hard too) but I will probably replace my battery as it is around that age,
And thank you I will check that out!
And like Eddie suggested, especially if you have never changed the cabin filter, I would do so.
You will be amazed how much crap they stop from entering the truck and how plugged up they become, restricting air flow for the HVAC.
The battery going bad will cause issues you would never even think of in the new "rolling computer" trucks we drive.
Edited by JimCost2014
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
