They just keep pushing the availability date back 2 week at a time. I wish they'd get them in stock already. Wanting to buy one.
Edited by Atomicgrl
For those who may still be interested, the site (ordered from rangetechnology) still says to allow 1-2 weeks due to demand.  However, mine came pretty fast.  Ordered late Tuesday, shipped Thursday, arrived Friday. Hardly sounds like a backlog, but maybe I just got lucky.
I purchased 2020 Chevy Trailboss 6.2L and I just hit over 6k miles and had take into shop bad lifters and bent rod.  Very disappointing.  I purchased the Pulsar LT today and when I get my truck back I plan to disable DFM and Auto/Stop Start.  I have noticed black res exhaust tail end cap or tips which indicates possible oil and gas issue also which could lead to carbon build up.  I hope turning off DFM will also resolve this and running all 8 cyl will burn properly and have cleaner exhaust. Think will also prolong life of engine (I hope) I’ve owned FORD , TOYOTA, NIssan but this is my first Chevy truck and having major engine issues 6k miles is concerning.
Welcome to the forum Eric.
Sorry to hear of your issue with the 6.2L.
When you mentioned the bent "rod" are you speaking of a piston rod or a pushrod?
BTW, you'll really like the Pulsar LT. 👍
Edited by Steve-2019
It’s pushrod.  Yeah everything I read says Pulsar must have to really get truck perform like it should.  I hope the new parts have resolved any manufacturing issue that causes failure in the first place.  My understanding trucks built certain time period has had this issue and have found these lifters didn’t meet spec and there were little to no quality control during COVID
Edited by Eric Rice
I have a 2020 GMC Sierra 6.2L.  I always drive using L3 thru L10.  I’m pretty sure this keeps all 8 cylinders firing & it keeps auto start / stop dis-engaged.
Does anyone else do this, agree or disagree with this?
I have over 6K miles & no problems to date.
 Thanks
Edited by Buzz Lite
I just installed the Pulsar LT on my 2021 Sierra AT4 6.2.  Five minutes to install the hardware.  10 minutes to program.  Very easy.  Speedo calibration for bigger tires worked perfectly when checked against GPS on Google maps.  My truck doesn't have Auto/Stop so I cant speak to that.  But the DFM is NOW DISABLED.  I have a Borla exhaust and I could always tell when it kicked into "chopper" mode.  Now V8 all the time.  Pricey, yes. Worth every penny. 👍
Edited by Luster
Yes, November ? 2020 through March ?, 2021.  There is a topic on this forum specifically about the defective lifter issue.  A GM tech who works at the engine plant stated that engines built before and after those dates have the "good" lifters and lifter springs and should be fine.  But I still disabled DFM anyway with the Pulsar LT, even though my engine was built way after the defective date.  DFM causes way too much wear and tear on the lifters and pushrods with the constant activate/deactivating!  V8 all the time is the way to go.  Be sure to remove the device prior to any dealer service appointment.  Only takes a couple minutes  to install/uninstall.  👍
Here's the link to the defective Lifter thread... Lifter issue: TSB PIP5776E - published June 18 - 2019-2021 Engine, Driveline, & Exhaust - GM-Trucks.com
Edited by Luster
To summarize the other thread... the motors affected were built before 3/4/2021. The TSB states the truck VIN build dates that are affected (with the aforementioned motors) are between 9/1/2020 & 3/31/2021.
Getting ready to pull the trigger on one of these to replace my Range device on my 2020 RST. My truck sits during the week because I have a company truck, so I have to unplug the Range device every time the truck sits for several days to make sure the battery doesn't drain down.
I'm curious if anyone with the Pulsar LT has a truck that sits for several days at a time. If so, have you had any battery drain with it?
I've had my Edge Products Pulsar LT for 4+ months now and my truck can sit untouched for up to two weeks with no issues of any battery drain. 👍
  • 6 months later...
On 3/4/2022 at 5:50 PM, Brooklyn21denali said:
Im selling my pulsar lt and the updater cable for 380$ shipped in the us.   Dm me if interested
glws, just curious about cable,  any significant updates?
 Thanks
Yes, I do the same thing, drive in L3 through L9 since I purchased the truck in March 2021. Also disable the auto stop/start every time I drive. So far, so good.
    tblt44
    tblt44
  • Who's Online   3 Members, 0 Anonymous, 524 Guests (See full list)
