Can anyone think of a scenario where these 3 buttons, Recirculate, Defrost, and Defrost/Feet would or should not be illuminated? Am I missing something? They do function and when pressed the little yellow/orange pill does light up to show it’s on. It’s just the icon itself on the button seems to be dead.
My recirculate button is like that.
Sent from my SM-G986U using Tapatalk
I never noticed it until driving home tonight. Maybe it’s always been like that and that’s how it’s supposed to be or something has gone haywire on me. Thought I’d ask here and get a census. Was thinking maybe “Auto” disabled them since it’s cold out and snowing. Sometimes (more often than not) the truck is smarter than me.
Thanks all. Something to mention and get fixed when I go in for my 30k mile oil change and tire rotation. At the rate I’m driving that won’t be for another few months! Maybe I’ll schedule something before that. It’s gonna drive me nuts.
I would say it is a bad HVAC control unit, if the buttons are not working at all. Don't think you can replace the bulbs either, been like that for the last few body styles.
Everything seems to be working except for the lighting on those 3 buttons. I’ll create an appointment to have it looked at. Warranty time!
1 hour ago, kenny_r said:
My defrost light just crapped out...pretty sweet for having 16k miles.lol
I’m at 28k miles with 3 lights out. You’re doing pretty good. ?
Yes sir, use it while you have it.
Just got back from the dealership. Will be replacing the module. Looks like its on national backorder at the moment but once it comes in it'll be swapped out.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
