Well.. spring her back into shape.  So to speak.  Bring on Spring already.
Busted valve spring on cylinder #4.  Just waiting on GM to give their 2 cents on how to handle.  Boroscoping the cylinders as well
Edited by Rob Mugs
I think that's the most miles I've seen on one with a failure.  Maybe miles don't even matter, just a matter of time....  Whats your build date?
Edited by RadBrad
55 minutes ago, 1997SierraSLT said:
Sure have to wonder if GM simply pulls another potentially defective valve spring out of their parts bin to be the lucky recipient in your engine.
Pretty sure it was one batch since they have build dates on the TSB.
Unsure on build date at this time
Welp, they have been nothing but helpful.  If you're in the area (NE Illinois) Ray Chevy.. kudos!
Getting a new engine and they're supplying me with another Silverado until it's done
Excellent, glad to hear they're doing the right thing!
And look at it this way, at least the issue it's out of the way now.  My truck was built in the time frame of the bulletin.  I feel like I'm driving a time bomb waiting for the engine to quit running.  Not an easy feeling if I go out of town.
How many miles do you have?
Just over 2500.
Maybe since I beat the crap out of this thing brand new on the test drive, raced a couple other trucks, took it down the track 5 times and did a few instrumented 1/4 mile tests, hopefully thinking a valve spring would have broken by now.
34 minutes ago, SILVER SLED said:
Just over 2500.
I did all of the above and broke at 2400... So could be on the horizon still
Well thanks for that but of info. Lol.  Mine actually has 2700 on it..
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
