I am going to go ahead and order a set since they have $100 off right now.  Was looking for some opinions on the regular steps vs. the Extreme steps that have 2 motors per side vs the standard one motor.  They say they are better for “extreme” environments.  I called today and Amp didn’t have much more to say then just that.  Figured they would have tried to push me to the extremes,   But they only gave me the canned one motor vs two.  I live in PA and do use my truck in all sorts of environments.  Mud, snow, ice, rain.  And the elusive sun.  It ends up being 350 more for the extreme steps.  And my logic usually is if one is good, two is better.  Thoughts?
That’s what I am thinking.  Of the issues I saw with them.  A few said they had some binding from the non-motorized bracket that needed constant lubricating.  Both brackets having their own Motors would eliminate that.  And let’s be honest.  They are already over priced.  Might as well get the whole enchilada.
Check out the RBP Stealth Power steps.  2 motors per side and better warranty than AMP.  I’ve had them for 5 months and love them.
Edited by Enviroag02
Almost pulled the trigger on these but decided to go with a fixed running board.  Did a ton of research and from what I learned the RBP Stealth Power steps were the way to go.  Priced better than the Amp Xtreme as well.
You can’t even see it when installed.  It’s way more subtle than the promo material leads you to believe.  I have a 6” lift and I have to try to look under to see it.  Can’t see it from the side.
On 12/31/2020 at 8:57 AM, Justin Vaughn said:
Man, they look like a good product but the branding on the bottom is cheesy af.
Where’s the branding?
Of course they are out of stock.  LoL. Do you have pics of them from further back?  Open and closed?  Can you plug into the OBD port like the amp steps do as well?
I have the AMP extremes and love them. I bought them because I travel in northern areas with difficult winter conditions.
Never had a problem with them.
Worth the extra imo
Tom
The RBP’s do not use the ODB port.  One of the reasons I prefer them actually.  Here are some more pics.
In my second winter with the normal Amps. Never had a problem with freezing up or anything else.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
