2022 GMC Sierra 2500HD SLE Doublecab X31 Cayenne Red gas
4-9-2022 Submitted online order to James Wood Decatur
4-15-2022 Signed order
4-20-2022 Order submitted to GM
4-26-2022 2000 - Order accepted by GM
6-10-2022 3400 - Order broadcast for production(Loaded on assembly plant computers)
6-18-2022  Has been produced, awaiting shipment.
7-7-2022 It's at the dealership.
7-9-2022 picked up and taken home
Edited by Texas1836
Updated info
Good luck with you order.
I had ordered my '22 LAST June, was built in November and was delivered to the dealer for me to pick up end of May this year.
Hopefully your process is not a SNAFU like mine.
Good looking truck you created.
On 6/4/2022 at 2:27 PM, Leonardo Willi said:
I read an article that 23' production orders start going in July 18 - anyone know whether there's truth to this or not?
 Also read where makeover was supposed ot begin with MY23, but that's been delayed to 2024 so 23's will be - basically 22's - correct me if that was bad info.
I spent many years in the auto part supplier business -- direct suppliers to the OEM's, including GM.
Used to be that all GM plants took a 2 week vacation in the last part of July.
During this time the supplier production employees took vacation too.  The maintenance and plant engineering types spent the 2 weeks doing maintenance items that were not possible in shorter time periods (including tooling / equpment mods/updates to suit the next model year requiremens.
Anyway -- it's possible that Jul8 18 is sop for '23 model.
It's also possible that Jul '18 is the start of 'summer shutdown' and the '23 sop is 2 weeks later --Aug 1.
Long winded way of saying that since '23 model pickup has very few changes vs the '22.5 (refreshed '22) it would be reasonable to think that the '23's will start late Ju or early Aug.
I've been away from the business for a lot of years, but sometimes, somebody that works for a Tier 1 supplier (ie direct to OEM) or at the assembly plant pops into these threads with the info for this year.
Edited by redwngr
Thanks. Fingers crossed it shows up in a month like the dealer thinks it will.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
