  • Replies 38
Top Posters In This Topic
Posted Images
Same issue.  2020 GMC 3500 Denali.  Went to “update software” but button is greyed out, says not a good time, try later.  Anybody found a fix?  Does updating resolve this?
Follow-up: a few days later apparently a “good time” finally arrived, my update button came back to life, software updated, back to normal radio operation.
Edited by Plympat
Update
My truck is a 2018, did it for the first time this week, i know last week i was told it updated, now having trouble, i assume from the update. The radio will not cut off, i have to remove the battery cable to get it to reset,
You might want to post this in your generation section.
  • 4 months later...
I just got a new 2025 silverado and about 20% of the time the radio won't shut off after you turn the truck off and open the door. There is no way to get the radio to turn off other than maybe disconnecting the battery. The on/off button won't work. Opening all the doors and shutting them doesn't work. All I can do is lock the doors and go in the house. Eventually it quits playing. I'm not very happy about this
Try hard rebooting the radio.  If you have the big 13 inch screen, vehicle on or running, press and hold the phone end call button that's on the right side of the steering wheel for 15 seconds.
  • 3 months later...
I bought 2024 GMC Sierra Elevation. I bought used just a month ago. Radio has always turned off when I open the door. Now it stays on. I have to power down the radio. It did show it had an update. I pushed the update but it is still staying on. What is the fix?
I’m having the same problem as mentioned above with my 2024 GMC Sierra.I  looked for updates nothing new and previous was March 2. I tried rebooting using button on steering wheel same thing happened  with radio so I tried a second reboot and right after second reboot I got an update now so I tapped to do update now. After update radio goes off when I turn off Sierra and open door . I went back to see what showed in the previous update area and only showed the March 2 update. I was going to post new  update tile / number. I will check again tomorrow or the next day and if there’s a new tile or number I will update my port with new info.
This just started happening in the last few days. I have had the Sierra for about a year  with know problems.
Update 6-1-25 I took my truck for quick ride this morning and when I parked in driveway I got a message for new update so I did update . When I restarted after update and then turned off radio went off when I opened driver door.  So not sure if it was the two reboots I did yesterday or the new update done today but so far radio turns off properly .
Edited by Borntorun
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
