  • Replies 38
Top Posters In This Topic
Posted Images
Same issue.  2020 GMC 3500 Denali.  Went to “update software” but button is greyed out, says not a good time, try later.  Anybody found a fix?  Does updating resolve this?
Follow-up: a few days later apparently a “good time” finally arrived, my update button came back to life, software updated, back to normal radio operation.
Edited by Plympat
Update
  • 1 year later...
  • 1 year later...
My truck is a 2018, did it for the first time this week, i know last week i was told it updated, now having trouble, i assume from the update. The radio will not cut off, i have to remove the battery cable to get it to reset,
You might want to post this in your generation section.
  • 4 months later...
I just got a new 2025 silverado and about 20% of the time the radio won't shut off after you turn the truck off and open the door. There is no way to get the radio to turn off other than maybe disconnecting the battery. The on/off button won't work. Opening all the doors and shutting them doesn't work. All I can do is lock the doors and go in the house. Eventually it quits playing. I'm not very happy about this
Try hard rebooting the radio.  If you have the big 13 inch screen, vehicle on or running, press and hold the phone end call button that's on the right side of the steering wheel for 15 seconds.
  • 3 months later...
I bought 2024 GMC Sierra Elevation. I bought used just a month ago. Radio has always turned off when I open the door. Now it stays on. I have to power down the radio. It did show it had an update. I pushed the update but it is still staying on. What is the fix?
I’m having the same problem as mentioned above with my 2024 GMC Sierra.I  looked for updates nothing new and previous was March 2. I tried rebooting using button on steering wheel same thing happened  with radio so I tried a second reboot and right after second reboot I got an update now so I tapped to do update now. After update radio goes off when I turn off Sierra and open door . I went back to see what showed in the previous update area and only showed the March 2 update. I was going to post new  update tile / number. I will check again tomorrow or the next day and if there’s a new tile or number I will update my port with new info.
This just started happening in the last few days. I have had the Sierra for about a year  with know problems.
Update 6-1-25 I took my truck for quick ride this morning and when I parked in driveway I got a message for new update so I did update . When I restarted after update and then turned off radio went off when I opened driver door.  So not sure if it was the two reboots I did yesterday or the new update done today but so far radio turns off properly .
Edited by Borntorun
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,087 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
