Looking for a unique color, just spotted this Trail Boss at local dealer (no affiliation)
Engine: 5.3L EcoTec3 V8 engine with DFM
Transmission: Automatic
Trim: LT Trail Boss
Color:Special Exterior Color
Installed Options
  • Leather Package $760.00
  • Bed Protection Package $685.00
  • Dark Essentials Package $305.00
  • Power sunroof $995.00
  • Performance Upgrade Package $2,275.00
  • Convenience Package II $1,300.00
  • Integrated trailer brake controller $275.00
  • Paints, solid, Tangier Orange $450.00
Edited by elcamino
I looked into these special paint colors, they do come direct from the factory, but I couldn’t understand why some had the weirdly painted front fenders either.
Couple guys on her ordered their trucks in the “shock” highlighter yellow. Definitely a stand out color.
Are the corner trim pieces plastic?
If so, it's likely because  the body may be painted before they are attached, and the trim supplier only produces in the 'main' colours, and not in the SEO colours.
There are currently abut 20 SEO colours listed for the 1500 Silverado.
(a bunch of them are not available on reg cab)
1 hour ago, lapoolboy said:
Front-end isn't even painted correctly making me think it's an aftermarket paint job.  Either way - eww.  Looks like it's for a road construction crew.
Nope, its all Chevrolet.
From the order guide
All normally body colored non-sheet metal parts will be black including front fender extensions, cab spoiler on Double & Crew cabs and LT trim door handles. May require extended lead time.
Edited by elcamino
It’s definitely a unique color?!?  The thing I do not like is the front fender painted black. Should just have it all orange.
I will say this, there are days that I long for a unique color of a vehicle because EVERYONE has a black truck “kinda” like mine. Now I know I customize it/ personalize it but from a distance many look the same.
Might look odd from side view but it looks fine from the front
The black extensions, bumper, grill, and cab spoiler I could handle. They can be painted to match.
The sunroof would be the deal breaker for me.
What wrong with a sunroof?
It's a hole in the sheet metal that lets sun in. We get enough of that through the windshield and windows down here. I would pay extra not to have one.
GM is having issues sealing the vertical glass on the rear windshield. No way I would trust a sunroof.
That dealership should pull the front fender pieces and paint match them. Other than that I like it. GM offers such boring colors for most of their lineup. Between that, wanting to be all electric, and ruining classic nameplates like Blazer, I'm starting to lose my patience with them.
I like it, should have a set of white Rally Stipes going over the hood, roof, and ending on the tailgate.
Apples to carrots..... To each their own (especially with this color) but I've had sunroofs on every vehicle outside of my Trans Ams with T-Tops.  No issues with the sunroofs, but you want to talk about leaks ?.  Get a T-Top car
Edited by Rob Mugs
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
