Yes. The dealership replaced the tailgate dampener and both switches. Not to jinx it but the tailgate seems fine. It took about a month for the parts to come in.
Have your dealership contact Central GMC in Norwood Ma and ask for Bill in service for more info....
My turn.... bought a year old 2020 AT4 last month. went to help a friend tow a boat home Friday and when we arrived after 45 minute drive the tailgate was down and an expensive marine battery was no where to be found! No chime or warning! I bought it to tow a camper with... I cannot have it come down while towing or it will contact the camper tongue jack ! Guess it’s going back to dealer!!!
Took my in on Tuesday, dealer disabled the switch at the tailgate and ordered a new one (waiting part).  The random opening and shutting in park has stop.  Until I get the new tailgate switch, I can only open/shut with dash switch or key fob.
So I'm having this issue now.
For me it's the main tailgate. First it started doing it after I had pressed the button. Clicking/unlocking over and over. Eventually would stop but every time I accessed the main gate by pushing the button it would start again.
Truck is going in for it's first oil change Friday. They are going to fix it then hopefully. I'm really surprised that this tailgate came out in 2019 and we're still experiencing this. Very frustrating.
Dealer replaced the switch in the tailgate and that fixed the issue with mine. Took about three weeks for the dealer to receive the new switch.
Thanks guys. I called ahead hoping they can get the order in.
Also, I couldn't take it anymore and disabled the switch. Hasn't happened again since I disconnected it. For me, it was the yellow wire pictured. You need to slide the red tab back in order to depress and unplug the switch.
Update: Dealer "fixed" the issue a couple weeks ago. Tech stated they repaired a loose connection. Well the thing started opening again the other day. It's back in the shop today (all day). They didn't finish diagnosis today because they performed an intellilink update and replaced my nicked steering wheel cover - that took 8 hours apparently. I will tell them to contact Central GMC in Norwood for the tailgate issue in the morning.
What is a reasonable compensation for warranty issues like this? This will be day three without my truck for this issue and they "don't have any loaners available"... If it weren't for COVID I would be screwed right now with getting to work.
That stinks, I had to wait about a  month for parts and it took them a half day to repair the issue. Have talk with Bill in Service.
I would have them disconnect the tailgate buttons while they order new switches. Your tailgate will still work via FOB and inside the cab switch (minus inner tailgate) without fearing it opening whenever.... It's been since early April since my repairs and fingers crossed... Two switches and dampener...
Friend of mine had a 2020 Sierra. His tailgate would randomly drop. Caused some damage when it dropped while towing a trailer. He had it to the dealer several times, they couldn't duplicate and refused to fix the damage. He got so frustrated he now drives a Ram. Talked to him a few days ago. He's much happier.
Yea I disconnected it myself when it started happening so that it wouldn't damage itself. That's why i posted those pics above for anyone else having the issue.
Bill isn't with Prime anymore. I spoke with the new service manager last time but I'll talk to him again about making this right. That's the most frustrating thing about this all... just make it right. Customer service is so dead (at least in MA). The dealership thinks that because this is a warranty issue that they don't have an obligation to make the customer happy. The free service is sufficient... well that's BS. $60k dollars later and no vehicle for 3 days... that inconvenience should be compensated.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
