Someone the other day asked about the new Silverado's and how they compare to a different make of truck the OP currently owned, well that got me thinking...can you guys smell the smoke from there?
If you could combine certain characteristics of any vehicle that you previously owned and combine them into a current and modern vehicle...what would they be and how would that look? Obviously everyone's idea of perfect is different, so I thought it might be fun to discuss, I'll go first.
I'd take the off-road ability and solid axle front end from my old 79 Bronco, the 6.2 and 10spd transmission from my current Silverado, pair those up in a Stepside reg cab like my 2001 Sierra and have one heck up a play truck
Edited by ThatredneckguyJamie
Frankentruck? This one is for sale at a nearby used car lot. It’s even worse in person.
69CBF4CE-55D4-4B99-9A1D-102880EC07CE.thumb.jpeg.e1e93b8cd5003daae6b6f881192d882f.jpegE2A1D683-4A36-4422-B857-6CF008F0C8E0.thumb.jpeg.c0149b02ae0a26ae945109e26643e98b.jpeg
  • Confused 1
Keep my 2015 K2 RCSB 2WD and Gen 5 4.3-6L80E drivetrain and shrink it to the size of my fathers 1998 GMT-400. Kind of like Smokey did to the 67 Chevelle for NASCAR. 7/8 size model. Then put it on a 500# diet. Install a mid 60's real bench seat. Put at the ride height of the GMT-400 2WD. Use the 4 wheel coil set up from a mid 60's half ton with softer springs and much better dampers.  They can keep the Infotainment center and give me an AM radio. 😉
  • Haha 3
Given my unique history vehicles, I think GM already made the Frankentruck that would result between my current truck and a previous car.  One of my previous cars was a 1988 Pontiac Fiero GT.  Combine it with my 2020 Silverado and you'd probably end up with a Chevy SSR.  However, I'd want a manual trans to go with the 6.2 and 10-speed.
I loved my 1986 Fiero GT. Beat a Porsche 911 in it going down 441 in Sarasota on the water front headed to 888 Boulevard of the Arts with a stock broker in the Porsche and my dumb-ass self in the Fiero just not caring.
Still, that Porsche was a really nice car!
Edited by MikeBMW
My wife had two. An 04 4 speed 4 cylinder and an 06 6cylinder GT. We had fun with those little Pontiacs. I almost bought one with a V-8 conversion.
7 hours ago, KARNUT said:
My wife had two. An 84 4 speed 4 cylinder and an 866cylinder GT. We had fun with those little Pontiacs. I almost bought one with a V-8 conversion.
Just now, KARNUT said:
7 hours ago, KARNUT said:.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
