Noob here.  I'm sorry if I'm not posting in the right place, but can anyone explain to me why the GM performance intake requires a calibration after installation, but none of the other after market CAIs from S&B, Roto Fab, etc. do not?
Because they can’t. GM locked down the ECM to make it very hard to make changes outside of a dealership. You need a new ECM unless you’re GM.
My last new truck was a 14 GMC. Every truck prior had hand held tunes, drop in or cold air intakes with exhaust. I never had a special tune or a check engine light. I can’t imagine there’s no room for a little more air in or a little more exhaust without special tuning. Not being able to make my truck a little different would just piss me off.
There’s room to work within the stock tune. GM themselves give you an extra 13 hp with their catback, no tune needed. Safe to say you can improve on the front end of that as well.
I ran the Roto-Fab for a few years, it did great. Never any check engine lights or other issues. I bought it for the look and sound first, but I did measure improvements with my Dragy as well.
Unfortunately the same few people here are far too exhausting to argue with. If you’re bored with the truck and want to add an intake system, do it. If not, that’s cool too.
Well that, plus it's likely required for CARB certification.
The thing with a CAI is that “ONE DOES NOT BUY IT FOR MPGs!!!  You buy one for the performance side of things. That’s why you buy it plain and simple. I have seen nice gains with my S&B intake along with my Corsa Exhaust.  Those who are in here constantly stating they don’t help (on performance side of things) are complete idiots! They choose to only b!tch about things and try to spat out a bunch of analytic garbage about air flow…blah,blah,blah
Here’s my offer for all those haters. Take a stock GM truck, then take one that has a full Catback exhaust and CAI and line them up. See which one “PERFORMS” better.  Oh wait, I have done this and mine performed better and I have seen 3 tenths sec better on that performance! Others have also shown numerical data as well.  Hell, GM states you get an extra 15 hp from both, and their CAI is garbage compared to S&B or Roto-Fab in terms of air flow.
As for the tunes, I am contemplating getting the Diablo hand held tune, just waiting on a time when I don’t need my truck for a good week because I don’t want to be stranded without a vehicle if shipping is late, because there is no way you are getting the ECU back in 1 day like they claim.
If I decided to install a S&B or Roto Fab CAI, would it be advantageous for me to take it to the dealer and have them do a MAF calibration on my truck as if I had purchased the GM performance intake?
(1) they won't do that
(2) that makes no sense.  The GM CAI/MAF calibration is specifically for a truck with a GM CAI, and in all theory, motor dependent.  A GM MAF calibration is not set up for any other brand air intakes.
Aside from the fact that they won't, I get that, why wouldn't it make sense?  Wouldn't the calibration be adjusting for a higher air flow over stock air flow?  Even though a K&B or Roto Fab wouldn't be the exact same as the GM CAI, wouldn't it be closer to it than it would be to the stock?
It makes no sense because if they are different air intakes, with completely airflow characteristics.  No, there is not a guarantee that it would be closer than a stock calibration.
If you are paranoid about a proper calibration for an air intake, then I'd recommend having your PCM sent to HP Tuners to be unlocked (over $1k), then having a shop do a custom tune for your specific modifications.  Which would, at that point, void your warranty.
You do not need a MAF re-calibration with the S&B intake. You follow the directions, un-hook the battery for 2 hours. Install the system and the MAF relearns itself. I've had mine on 2 vehicles, with over 30k miles and nothing has ever come up other than forgetting to take off the air filter indicator in the settings menu.  I believe Roto-Fab is pretty much the same thing.  I just choose the S&B because of the price and it has the best air flow out of all manufacturers out there. I would buy either one if I had to choose again.
So if the MAF relearns or re-calibrates itself after installation of an after market CAI, why can't it do the same with the GM performance intake?  Why does the GM performance intake require a re-calibration?
Same reason the manufacturers do everything. There’s probably a little extra horsepower if you buy from GM. They want control. And there’s the warranty excuse. Otherwise it’s smoke. Take your pick. Like my 14 for instance with the E-85 option. Extra HP just by adding E-85. Put a can tune on it same HP using premium fuel. Voiding the warranty potentially. Control.
Just because it can relearn within its current parameters doesn't mean there isn't a benefit to tune specifically for it. From what I've read the tune is to compensate for MAF sensor relocation. Plus this is the only intake to have CARB certification as well, so that likely has something to do with it as well.
  • 4 months later...
Will chime in with my experience with a new S&B install. I have a 2021 AT4 6.2 with a fabtech kit on it (coil overs up front with new rear shocks lifted about 3 inches over a stock AT4). From an MPG perspective, I was getting about 13.5 around town and after 500 miles with the S&B, I am seeing in the low 14s. With really reserved driving I get over 15. Not a huge jump but more than I was getting before. I did not reset the MPG counter prior to installing BTW so it was still showing its original numbers. I haven’t done enough highway driving yet to see if there is any benefit there but the fact that it did not go down is a bonus itself.
I will say that I have had a few check engine lights since installing mine. Each happened after about 150 miles of driving. The first time I pulled the battery and made sure everything was tight and let it sit for a few hours to clear whatever caused it. Even though I had tightened everything at the time of install, the MAF screws were a bit loose and so was one side of the MAF extension cable. The second time it happened I was our running errands and the light cleared itself and hasn’t come back on with another ~100 miles of driving.
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
