Hello
I am trying to figure out which spark plug wires fit my engine, but I couldn’t figure it out.
Mine is 2018 Tahoe Premier 5.3L
I was looking for Accel (part# 9059C) & MSD (part# MSD33829), but for both, some websites claims that it will not fit!
Can someone confirms which may fit so I can buy.
I am welling to use ACDelco sparks plugs
Thanks
https://www.holley.com/products/ignition/spark_plug_wires/accel_ceramic_boot_spark_plug_wires/parts/9059C
https://www.amazon.com/MSD-33829-Spark-Plug-Wire/dp/B01FV3GR3O
 The oe wires are best, same goes for plugs. CSP swapped in msd wires on a C7 build and they lost 40 something horsepower compared to acdelco. The msd's had no damage and were functioning properly. Apparently its not all about resistance.
Stay away from Granatelli. Any company that sells a ported maf sensor should be avoided like covid-19!
Edited by M1ck3y
This is the MSD size that fit my old 2014 5.3L engine:
# 33829
I am running Taylor wires now on my Silverado which I like a lot. Better than MSD. part number is:
# 79613
I personally don't like the factory wires or plugs. I find both fail way too soon. Replaced every set on over 5 GM trucks before the warrantee ran out usually. Always been happy with the results, and always found the factory sets in bad shape in as little as 40k miles. Would never buy them. I have heard that too low a resistance can lead to misfires, but have not had that issue with the Taylors.
 need resistance in the wires and in the spark plugs, otherwise the coil doesnt charge up fully, you'll get weaker spark. the resistor is apart of the engineering, by holding back the energy until it blows it's load so to speak.. and its needed for noise suppresion so not to interfere with the ecu , radio, bcm, etc..
a points distributer likes low resistance, because its all mechanical and takes time to transfer spark thru the ignition, HEI is different
Edited by pokismoki
Spark happens AFTER the coil is charged. Coil near plug systems so have more than enough time to charge...fully. Not one coil per eight but eight coils per eight. Coils fail to charge fully when the time between sparks is less than the rise time of the coil. If what was being said were true then coil on plug systems would not work at all. Right?
This is basic Ohms' Law once the system 'asks' for the spark.
Spiral wound wires provide more than enough suppression IF the wrap per inch is high enough.
why does Honda use a resister plug on their single cylinder thumper dirtbike motors??
if the resister suppresses current, does this mean it improves the voltage spark?
this was informative for me..
Edited by pokismoki
40 Hp wow, is it possible they are giving off so much noise it's effecting the ignition timing. those wires might be designed for Magneto ignition and not HEI COP style
They were the wires MSD specd for the LT1/l86 etc. It was a high horsepower build. I imagine the difference on a stock engine would be minimal.
When I have time I'll try and find the video on YouTube again.
*Edit*
The focus of the video wasn't about how the msd's lost power so I can't search for it and pull it up. Way too many videos to go through. If someone has an interest in hunting it down, the video was done by complete street performance.
Edited by M1ck3y
Current is energy. Voltage is potential. You light a fire with energy. A few millijoules. About 17 millijoules will get it done if everything is perfect. It rarely is. You jump the gap with voltage. Want more voltage increase the gap. Takes about a thousand volts per thousandths of an inch of gap in free air.  What has more resistance than air? Just because a coil can put out 50K volts doesn't mean it will. It will put up what it needs to jump the gap. Not a volt more or less.
Older English bikes used carbon/cotton wires and non resistor plugs and some dismally weak coils. Kettering ignitions are not bothered by noise. Honda's electronic systems are. They could use a suppression wire or plug but both is never required. They became popular in cars when AM radio got to be a big thing.
Honda cars. The 4's anyway are coil on plug. There is no wire thus no resistance that is not provided by the plug. By present argument these motors shouldn't run should they? 😉
Read the Magnacore link M1ck3y6 provided.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
