In one of the videos for the reveal, I noticed a digital image on the gauge cluster of what looks like to be the LTZ model.
Edited by ausomecasey
  • ausomecasey changed the title to 2022 Silverado 1500 LTZ Refresh Image
The funny thing is that exact image was showing up on the ZR2 😉
I hope it’s selectable. Ideally it would be customizable (ie you can load an image off a USB stick).
I like the "enhanced" front end for the main reason that GM finally combined the DRL and the turnsignal (like they did with the SUVs). It looks good. Hopefully the headlight throw / pattern will be a little better off the periphery, which is why GM got dinged on the safety ratings for the T1s.
But the placement of the bowtie just screams "Hey, look... we changed the truck!". It's so odd to put it ABOVE the center crossbar / line on the grill. I don't think it looks terrible, but I don't think it looks good, either.
It just looks like they wanted people to be able to quickly tell someone was driving a 2022 vs. a 2019-2021.
And I don't totally blame them for that... because the 2021 F150 is so similar to the previous F150, I feel bad for people paying money to upgrade... because the average Joe would never be able to know it was a "new" truck. 😂
Adding onto my comment above, I think the "flowtie" of the ZR2 looks best on this new front end because it's hallow... so it does not stick out as sorely as the yellow bow tie on the LT/LTZ and HC will. I think the black on the TB and RST won't look as odd.
Yea I have always been a fan of the classic gold bowtie, but I might end up liking the black better this time.
When I saw the hollow bowtie I almost for a second thought we might be getting a supercharged truck because of the ZL1, wishful thinking! I prefer a black bowtie to the yellow one although on my 99 I have a Texas flag bowtie
1 hour ago, mafd2 said:
Here's a vid showing the 2022 LTZ.
This is just a rendering, and it's not accurate. It still has the old grille, just moved the bowtie up. The LED signatures are also wrong on this rendering. It was a good guess, though.
The pic in the image on the ZR2 digital dash is for sure what the LTZ will look like.
I understand but I think it'll be really close even though it 's a CGI.  I'm sure they used the photos between the LT, ZR2 to model it.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
