Long lurker, but first post. I’ve done quite a bit of educational reading here on many threads and wanted to inquire on something.
I’m in the market for a 14-18 Silverado or Sierra 1500. Ironically, I have an opportunity to score a very nice, almost ridiculously nice, condition 2014 6.2 SLT with the max trailering package (3.73) and acceptably low mileage. It has almost all, minus a few not so important, options I’d like. 2014 is really the only way to get one of these trucks w/o getting the 8 speed, unless I’m mistaken, so between that, age/mileage, and certainly factoring in the max trailing pkg, such a combo is difficult to find. Plenty of options exist to get the big motor in 15-18 trucks with the 8 speed, with max t pkg if necessary.
Now, I don’t know that I’d go so far as saying that I prefer the “smoothness” of the 6 speed relative to the 8 speed but in our Yukon XL SLT (5.3/6 speed), honestly it offers a rather pleasant city and highway driving experience lugging around the kids. Mind you, we aren’t racing it with the kiddos onboard. It’s not quick, by any means, but it does the job.  I’d want more in a truck, thus the 6.2 thinking. Now, I’ve driven 5.3 + 8 speed combos and other non GM > 6 speeds, and they always feel jerky to me when doing simple cruising around town. I don’t feel it matters much on the highway, honestly. At elevated speeds, the feel difference is minimal IMO. I have NOT driven a 6.2/8 speed….yet.
The general consensus in my reading here is that the 3.73 ratio in the 6 speed really makes the 6.2 come alive - several threads about towing (which I don’t do a lot of), quickness/fun-ness (important to me), etc. In addition, one might even say some feel the 8 speed should be avoided, others say just jump to the 10 speed. Opinions vary.
My question is, given the 8L90 issues, short lifespan relatively, etc does it make any sense to specifically consider an “older” 6.2/6L80/3.73 vs a 2015-2018 6.2/8L90 combo?  Or have a lost my mind completely due to information overload?  My primary concern is long term durability/reliability. Obviously, I don’t want a train wreck, and first year roll outs in a series always make me a little nervous even though the truck in question literally has been near flawless across its life.
Curious what you connoisseurs and those having more experience in all these combos might do here - consider the 6.2/6L80/3.73 purchase, re-focus on a 6.2/8L90 - with or w/o NHT (I think is the code), or sit tight until a 6.2/10’s come into my budget a year or so from now?
Diff ratios used on 8 speed are different that 6 speed.
I think you find that the overall ratio (trans and diff) with the 8 speed gives a lower low and a higher high than the 6 speed.
Same deal with the max tow (NHT versions) which has higher (numerically) ratio diff's.
My 14 (non max tow package) had the 3.42 6 speed, very quick truck off the line, and held RPM's a little higher, not as much 'lugging" at lower speeds.
The 16 I had, and now my 18 have/had the 3.23 8 speeds. Both have been very good, but takes a little more "motivation" to get them going at the same pace as my 14. Better MPG's with the 8 speeds, and tow just fine.
If you are looking at K2's, would really consider an 18, seems like it was the year they finally got most of the bugs worked out IMO.
I posted a gear ratio spread sheet a while back comparing the 6 speed with 3.73's to the 8 and 10 speed  with the 3.23's and the 8 and 10 speed had "lower lowers and higher highs" as posted above.  The key though isn't how "low" the overall gear is, its how long the truck stays in that gear range and the 8spd and 10spd manage to operate in the lower gear ratio parameters for a longer duration than the 6 speed which in turn allows the vehicle to pull harder for longer even though the rear gear ratio is taller.  I'll see if I can find my spread sheet and post it again.
6 Spd Auto Gearing (X:1)   4 Hi Final Ratios 4 Lo Final Ratios
1 4.03   15.03 40.44
2 2.36   8.80 23.68
3 1.53   5.71 15.35
4 1.15   4.29 11.54
5 0.85   3.17 8.53
6 0.67   2.50 6.72
Reverse 3.06   11.41 30.70
Axle Ratio 3.73   Crawl Gear Ratio (X:1)
      40.44
Transfer Case
4 Hi 1
4 Lo 2.69
8 Spd Auto Gearing (X:1)   4 Hi Final Ratios 4 Lo Final Ratios
1 4.56   14.73 39.62
2 2.97   9.59 25.81
3 2.08   6.72 18.07
4 1.69   5.46 14.68
5 1.27   4.10 11.03
6 1   3.23 8.69
7 0.85   2.75 7.39
8 0.65   2.10 5.65
Reverse 4.86   15.70 42.23
Axle Ratio 3.23   Crawl Gear Ratio (X:1)
      39.62
Transfer Case
4 Hi 1
4 Lo 2.69
10 Spd Auto Gearing (X:1)   4 Hi Final Ratios 4 Lo Final Ratios
1 4.7   15.18 40.84
2 2.99   9.66 25.98
3 2.15   6.94 18.68
4 1.8   5.81 15.64
5 1.52   4.91 13.21
6 1.28   4.13 11.12
7 1   3.23 8.69
8 0.85   2.75 7.39
9 0.69   2.23 6.00
10 0.64   2.07 5.56
Reverse 4.87   15.73 42.31
      40.84
Transfer Case
4 Hi 1
4 Lo 2.69
Those are based on my own calculations from materials I have reviewed.  The reverse gear ratios would need to be validated.
Basically, the 8 speed and 10 speed transmissions do everything better, from top to bottom, even when the 6 spd is paired with the 3.73's.  If you pair the 6L80 with 3.42's or 3.23's then the 6l80 is not even remotely close.  The only real question would come down to reliability in which case the early 8 speeds did have issues but those same issues seem to be resolved in the newer models.  I have not had a single hiccup from my 2020 8-spd and I have 45k miles on it.
if you can score a clean truck pre-2017 get that sona-******, , the computer are easier to access and tune.
i know the tuners like the 8 speed because it can handle over 1000hp, but cost is not friendly for the home tuner. tcm unlocks $$$ the 8 speed can shift faster, but has way more rotational mass which robs you of power transfer.
6l80/90 is the way to go if you want tuning on a budget, the 2500 trucks is the best 6 speed, its built stronger as a 6L90.
Edited by pokismoki
6L80 has a higher issue rate than the 8L90, at least where I work.  All day long.  I've lost track on how many 6L torque converters we've done, on how many got fluid pumps and some internals, on 4-5-6 clutch failures, entire transmission replacements because so much converter clutch material an metal went through them.
8L90 I would go 2018+newer.  If it hasn't had the fluid swapped out for shudder that would be the first thing to do.  Some of the funky shifts can be settled out by making that specific gear change like 15-20 times at the throttle % it does it.  Helps to learn that clutch/gear change.  So say you have a funky 2-3 shift, pop it into manual mode and make a bunch of 2-3 shifts.
As far as how they run/drive.  I'm on my 4th 6L.  I love them for the most part, but 8L and 10L drive sooo much better, especially the 8L in the T1 new trucks.  They tightened up the shift calibrations and tuning much better.
3.73/6speed vs 3.42/8speed.  The 3.42/8speed would have even more gear multiplication throughout 1-4th or 5th gears.  8 speed lets the engine sit in the HP and or TQ bands better.  Watch some of the Ike Gauntlet videos on TFL truck.  Yes, the test is a more extreme test and and high elevation, but you can see where some of the GM 6 speeds fall short of the 8 and 10 speed trucks.  6 speed can get stuck in a lugging zone and start to fall off RPMs and out of the meat of the power range.  Even with 4.10s.
6.2 8 speed NHT 3.42
2017 Chevy Silverado 1500 6.2L V8 vs Ike Gauntlet Review: World's Toughest Towing Test - YouTube
6.0 HD 6 speed 4.10
2015 Chevy Silverado 2500 takes on the Grueling Ike Gauntlet HD Towing Test - YouTube
6.6 new gas HD 6 speed 3.73
The New 2020 Chevy Silverado HD Gasser Broke Our Ike Gauntlet Scoring System - Here Is How! - YouTube
I know there is weight differences in the videos above, but you can still see how the two HD trucks get put in strange positions during the pull.  The switch DOWN to 3.73s in the 2020+HD was a mistake as well.  That truck needs the 10 speed all day long with those 3.73s.
Edited by newdude
Sorry all.  I've been away on business for a bit.
Thank you for all your input.  This clarifies a lot of question marks I had.  Now it's time to take a few different configurations for a spin and complete the "feel" evaluation.
Besides, the used car value/market is completely out of control (high) at the moment, so exercising a little patience is probably a good idea honestly.
Thanks again.
On 10/29/2021 at 7:35 AM, pokismoki said:
wow, on the 10 speed that 1st (4.7)gear transition to 2nd (2.99)gear must be an annoying shift
Nope.  Not at all.
17 hours ago, Transient said:
Nope.  Not at all.
Agreed.
Behind the 3.0 it is buttery smooth.
(is that a technical description??)
Edited by redwngr
It's too bad we won't get to see a 12 speed. Four or Five overdrive gears would have been great on the highway.
Edited by M1ck3y
Interesting fact. A lot of people complain about the gearing being so low compared to competitors. But if you pick the correct (Taller tire) for your application you can reduce your 0-60 mph etc.
For ex. I put on slightly larger tires changing the axle ratio to 3.19 from 3.23. I know, small change. But enough that it now shift's just after 60mph and the 1/4 mile making better time. A lot of factors in this. But if you're traction limited a taller tire could be the way to go.
That is, if you use trucks for things they weren't intended for 😜
And taller tire's cover more ground. Less rpm for distance traveled so.. quicker at higher speeds
Edited by M1ck3y
6 hours ago, redwngr said:
Agreed.
I have the 6.2.  That's 2 engines with the same trans both agreeing.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
