 I do apologize if this isn't the correct place to ask this question. I'm in the market for a good OBDII scanner that would meet the typical DYI'er's needs. I've been reading about them online and, honestly, it can get a little overwhelming. I'd like to keep the cost under $200, any recommendations?
I use a Foxwell NT510 elite for GM and it has quite a lot of functions.  I use for my Silverado and Saturn.  I like it and it was  under $200.  I hope you find a scanner that works for you!!
I went cheap and got a Bluetooth one. It will read and give you the codes and also allow you to clear them. It is linked to my android phone using the app Torque Pro by Ian Hawkins. The Torque Pro I believe is a paid app but there is a free Torque Lite available as well. I bought it several years ago and it has served its purpose. The Torque Pro also allows you to monitor different functions as well.
Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light https://smile.amazon.com/dp/B005NLQAHS/ref=cm_sw_r_apan_glt_fabc_A2SX332AHWEHSJHQ0SDB?_encoding=UTF8&psc=1
Edited by mikeyk101
Depend on your needs. To best recommend a device, what are you looking to perform?
1. Something basic such as read and clear common code.
2. Able to perform more functions such as abs, brake bleed. Note alot of the basic reader does not have this function.
3. Access GM modules/program modules
All depends on what you want to achieve.  I have a $20 dollar code reader and it perform just as well as my $90 Bluedriver. Around $120, I can do things I wish I knew before purchasing the Bluedriver, it turns Bluedriver into a dust collector.
To do that, one will need a scanner that is more than $200.
I have an Autel MaxiSys - I like to work on cars.
I, also, have an Autosync with BTDiesel which unlocks the BCM and HMI for programming.
Also, a SuperChips F5 for unlocking the ECM.
If one just wants to read codes, and get resulting information, there are many.
If one wants to reprogram modules and dig in deeper, it's gonna cost a lot.
This is something that I have been thinking about. I'm the type of person that would like to have it and not need it, than to need it and not have it. I'd like to be able to read codes on multiple different vehicles. I'd also like to be able to access the GM modules that are in my truck.
- I've been looking at the Foxwell NT614
Thoughts?
That looks good for most DIY at home.
I have the vcx nano for GM. It already paid for itself after one use. I bought my truck used with only 1 set of key yet the truck shows 2 set of keys being active. I used it to deactivated all key/fob, cut my own keys and reprogram 3 set of key/fob. Just imagine how much the stealership would charge just to cut and program. I have also use it to program other modules thru ACDelco SPS services, an additional $40 access for 2 years.
For something quick/on the go/portable, I uses the $20 scanner along with torque pro. It's hook up to my spare phone which is linked to my truck via Android Auto. I can scan for codes on my truck's 8 inch screen.
I started a thread in the mod section if you're interested.
torque pro is ok, but if i found the pids  and other parameters where incorrect, and would give erroneous data.
 just get the HPtuners obd module, you can thank me later
Edited by pokismoki
It all depends on what you want.
i. If you want a cheap scanner
ii. Bluetooth scanner
iii. live data and more features that you want.
Then you want to check out these models, Blue Driver Bluetooth Professional OBDII, Scan Tool 426101 OBD Link MX Bluetooth, BAFX Products Bluetooth Diagnostic OBDII Reader. https://theeffectiveguide.com/best-obd2-scanner/best-obdii-bluetooth-scanner-reviews/bluedriver-obd2-reviews/
I hope you find that scanner that you want
Edited by Kevin N.
    CockneyUSA
    CockneyUSA
  • Who's Online   4 Members, 1 Anonymous, 756 Guests (See full list)
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
