2015 Crew Cab 4x4, 5.3L, almost 90k.
Ran into an issue where the truck would "bark" on downshift with the engine under some load. Example: Drive along at 30-40MPH on a level road, truck settles in an drops RPM's to "cruise" along. Road slopes upward into an actual hill (not just a small incline). Push down on the accelerator to maintain speed, truck drops at least 2 gears. At the -exact- moment of the downshift, there's a sort of 'barking' noise emitted which can vary in duration and volume. The very first time it happened, I was speeding up to move to the left lane on the highway at the moment I was starting to climb a grade. I was traveling around 60MPH and the truck dropped at least two gears on the downshift. The noise was fairly loud and lasted 1-2 seconds in length.
Dealer has indicated that the issue is related to a mechanical valve at the rear portion of the exhaust (directly in front of the muffler) and it's part of a complete muffler system. In other words, the only way to correct it is to replace the entire exhaust which simply isn't happening, at least not at dealer prices. They've also stated that the valve can't be lubricated in any way to address the issue. I've seen the valve they're talking about, and that entire area is reasonably corroded after 6 New England winters of driving.
Thoughts on how to address this other than a complete exhaust swap?
Here is a thread about the flapper valve, might be of help?
I have no direct knowledge to guide you, just offering assitance. :)
Thanks. I wish I could figure out if that part were serviceable in any way without replacing the entire assembly. Dealer says it can't be lubricated or anything.
Anything you put on will burn off.
Was listening to the "flapper valve" in our 2016 LTZ Tahoe today coming down Highway 410 from Crystal Mountain.
Every time it switched from V4 to V8, and back, you could here the "squeak" as it operated. Nothing says "world class build" in a vehicle with a MSRP of $75,000.00 like a constant annoying noise during your trip🤔😬
What about something dry like a graphite, though? I realize that any liquid-based lubricant wouldn't hold up, but wasn't sure if there might be something that wouldn't be affected.
It would have been nice if they had made all of the valve components out of stainless steel to prevent the rot/rust problem that has led to the squeak.
Dealer wants $1400 to replace the muffler because that valve is part of the complete system and apparently not available as an individual piece. I can buy the part for about $450 and have my mechanic put it on for under $200. No way the dealer is getting more than double that for the same repair. If I decided not to do anything about it at all for six months, maybe I'll do the repair myself next spring when I won't be freezing to death under the truck.  :)
You would have to find a lubricant that is designed to survive probably a minimum of 500 degrees.
That being said, you could try applying an anti seize/rust killer like corrosion free, rust check etc. One that's designed to penetrate and break up the rust.
Let it sit for a couple days and do it's work. Worth a shot anyways?
I imagine it's the outside spring and/or connection at the housing thats squeaking. Probably no need to try and spray the inside.
Edited by M1ck3y
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
