Buggy whip salesman are crying in their beer again....LOL   Disclaimer I am not plugging EV transport, hell I am a retired Chem Engineer from a major engine maker.
Our transport and energy system was set up for  extracted from the ground hydrocarbons because it is plentiful and cheap. Standard oil and Rockefeller drove that. For over 100 years it's been true.
Anyone remember Teapot Dome scandal? Didn't think so.
If in that 100+ years Edison or Tesla had been funded for EV transport fueling we'd be so far ahead of the arguments being made here people would be screaming that its un-American to consider burning the precious feedstocks for chemicals and plastics as a fuel.
In the oil industry there was nothing about FREE markets in its formation or dominance. The US gov allowed and encouraged its use and today still subsidizes it.
So the  INFORMED US citizen can decide by voting where we head and the market will follow.  MACRO ECON is like that in a democratic republic.  Now if the citizen is uniformed or misinformed or chooses not to vote,.... well thats where rich powerful people do things to them that are sinful.  Some even like having sinful things done to them by powerful folks.  LOL
  • Haha 1
  • 3 weeks later...
  • 1 month later...
BATTERY ELECTRIC VEHICLES NOT READY
"While that statement my fly in the face the current trends in global emissions regulations and the electrification strategies of many OEMs, Sencal later outlines several advanced technologies and strategies for the reduction of CO2 emissions from the ICE such as Gasoline Compression Ignition, Premixed Charge Compression Ignition, and dedicated EGR systems as well as options for carbon-neutral fuels. “If today’s ICEs operate at, say 12-35% efficiency for gasoline engines, its possible that with one or more of these advanced concepts…an overall vehicle efficiency of 80% is possible with an ICE efficiency of 60%.” "
Racing Toward Zero: The Untold Story of Driving Green was published in 2021 by SAE International. Its ISBN is 978-1-4686-0146-6 and is available for download both in digital or print formats on SAE’s website for $28 USD.
  • Thanks 1
Large heavy batteries are not the answer but a bridge technology, here's where I think we are headed for execution
https://www.cummins.com/new-power/applications/about-hydrogen/electrolysis
Edited by customboss
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
44 minutes ago, diyer2 said:
Rivian Electric Vehicle Maker
https://rivian.com/
Google biggest investor. Company to make EV for Google.
I read that. I also read some electric vehicles caught in flooding catching fire. I wonder if you get caught in a flash flood what about electrocution. Even if you bailed out into the drink to get away.
  • Thanks 1
Hydrogen and fuel cells is the future!!!  it retains the current petroleum infrastructure , and meets the green zero emmissions goals.  Lithium battery tech just doesn't have what it takes to replace ICE vehicles
if Rivian had thier ****** together they would drop all battery tech and convert to the fuelcell system
Edited by pokismoki
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
