jonwit Posted November 20, 2021 Posted November 20, 2021 After remote start, the truck blasts air until you put the key in, then (and only then) it goes back to whatever setting it was on when you last turned the truck off. I'm guessing this is some attempt to make the interior "cool down" or "warmup" before you get in. But it's terrible. Anybody figure out how to disable this stupid feature!?!?
GETGONE Posted November 20, 2021 Posted November 20, 2021 It's part of the auto or semi-auto climate control and will run the heat or AC to bring it up or down to temp. I'm not sure what the exact temp is. Why is this an issue?
Atlas Posted November 22, 2021 Posted November 22, 2021 You can specify parameters for climate control when started remotely - it's in the vehicle settings menus accessed from the radio.
GETGONE Posted November 23, 2021 Posted November 23, 2021 Not on the Custom trim level. Would be the same on any trim with single zone climate control.
jonwit Posted November 23, 2021 Author Posted November 23, 2021 On 11/19/2021 at 9:55 PM, GETGONE said: It's part of the auto or semi-auto climate control and will run the heat or AC to bring it up or down to temp. I'm not sure what the exact temp is. Why is this an issue? Because it's annoying
newdude Posted November 23, 2021 Posted November 23, 2021 On 11/19/2021 at 8:18 PM, jonwit said: After remote start, the truck blasts air until you put the key in, then (and only then) it goes back to whatever setting it was on when you last turned the truck off. I'm guessing this is some attempt to make the interior "cool down" or "warmup" before you get in. But it's terrible. Anybody figure out how to disable this stupid feature!?!? No can disable: DUAL ZONE AUTO CLIMATE OPERATION DURING REMOTE START: Cold ambient temperature that is below 50°F (10°C): Mode = Defrost Temperature = Full Hot Blower = Six bars Recirculation = Fresh Air A/C compressor = Only commanded on if conditions allow compressor engagement. Hot ambient temperature that is above 59°F (15°C): Mode = Last known settings Temperature = Full Cold Blower = Last known settings, unless the blower was in the "Off" position. In which case, the blower will be turned to the "Auto" setting. Recirculation = Recirculation A/C compressor = On Mid ambient temperature that is anything between the cold and hot ambient temperature values: Mode = Last known setting Temperature = Last known setting(s) Blower = Last known setting Recirculation = Last known setting A/C compressor = Last known setting SINGLE ZONE MANUAL CLIMATE OPERATION DURING REMOTE START: Cold ambient temperature - below 50°F (10°C): Mode = Defrost Temperature = Full Hot Blower = 8 Recirculation = Fresh Air A/C compressor = Only commanded on if conditions allow compressor engagement. Hot ambient temperature - above 59°F (15°C): Mode = Panel Vents Temperature = Full Cold Blower = 8 Recirculation = Recirculate A/C compressor = On Mid ambient temperature - anything in between "cold" and "hot" ambient temperature values that are listed above: Mode = Last known setting Temperature = Last known setting Blower = Last known setting Recirculation = Last known setting A/C compressor = Last known setting 1 1
bjr2020 6.2 Posted November 26, 2021 Posted November 26, 2021 So are you saying it can be disabled? If thats the case plz explain for us single zone folk's lol.
Steve-2019 Posted November 26, 2021 Posted November 26, 2021 4 hours ago, bjr2020 6.2 said: So are you saying it can be disabled? If thats the case plz explain for us single zone folk's lol. No, it can not be disabled.
GETGONE Posted November 27, 2021 Posted November 27, 2021 How is it a bad design? That's the whole POINT of having remote start is to warm or cool the interior!!!! 4 1
Transient Posted November 28, 2021 Posted November 28, 2021 Mods, Can we get a facepalm emoticon? If this is a bad design, then it's been a bad design for about 20 years. 20 years of history and the odds are you're in the minority group of dissatisfied owners. 3
Bigfoot98 Posted December 5, 2021 Posted December 5, 2021 On 11/19/2021 at 8:18 PM, jonwit said: After remote start, the truck blasts air until you put the key in, then (and only then) it goes back to whatever setting it was on when you last turned the truck off. I'm guessing this is some attempt to make the interior "cool down" or "warmup" before you get in. But it's terrible. Anybody figure out how to disable this stupid feature!?!? What's stupid about it? The entire point of remote start is to make the cabin comfortable, it its hot it blows cold and if its cold it heats it up, turns on the window defrost, heated mirriors steering wheel and seats How's it annoying? Really how? Dont remote start the vehicle if you dont want to use its features You can disable some of the heaters in vehicle setting on the radio, same place for the windows down from keyfob and horn alerts, rear seat reminder and what not
bjr2020 6.2 Posted December 7, 2021 Posted December 7, 2021 I was referring to the fact you can't adjust the fan speed at all during remote start on the custom trucks.
Ithan Henry Posted December 14, 2021 Posted December 14, 2021 On 11/27/2021 at 12:49 PM, GETGONE said: How is it a bad design? That's the whole POINT of having remote start is to warm or cool the interior!!!! Remote start is great, but I think 60 degrees is too cool for full air. Probably should have bumped that up to 70. I've got the Custom trim so no adjusting for me.
Register a new accountSign in
