It's been awhile since I posted and didn't really like the new style of forum posting as it seems more tuned to phones.  I am not much into phones?  Guess that makes me old...Oh.well!
I just had a major, major mechanical fiasco the other day.  The truck just wouldn't get up to temp so I watched "her" real close.  Normally, I have AM radio cranked up and HOT COFFEE and paying attention to the other idiots on the road seems like a better idea than watching my dummy gauges.  Long story short is $70.00 for a thermostat/all in one with housing about made me crap my pants because prices are going up but this is rather obscene don't ya think?  I don't know what else to say really other than I am gunning for Cadillac Luke on mileage and keeping Grumps at bay from my mileage!
As a reminder folks:  AFM is enabled, and every other thing like the junk 8speed is all original and like grumps says, "It runs perfectly fine until it finally dies" It's great to be the luckiest GM owner on the planet because this thing is classic GM Body of Frame truck.....runs forever!
  • Haha 1
Oh boy are you lucky. Pepper is in her seasonal down time at 151,556 miles and still without issue. 😉 Luke cracked 200K some months ago. Popped in. Popped out and like smoke....gone again. :crackup:
Sticker shock on that thermostat? They were at one time listing $90. At some price people just quite paying. I pitched that over priced scrap and installed this from IPSOCO and run a standard good old 54 mm SBC Stant or Gates Super. Not a breakdown part but a "Shinny...I want Precious" sort of thing.
A year or two ago I replaced this starter shield that was rubbing on the flywheel ring gear. Drove me nutty.
Bzzzzzzzzzzzzzzzzzzzzzz
Pinion seal real early on.
She still cleans up well.
About $20 in "repair" parts over 150K miles.
Finally put tires on it at 125K 😱
How about some pictures of that whip Mooooook?
Edited by Grumpy Bear
turned 150k this week. finally just did brakes and rotors, found both rear seals leaking so i replaced them also. a week later the pinion seal is leaking wtf. had to put the truck in the shop to change the thermostat for a second time because it wouldnt get to operating temp. i decided to check the rear axle vent and found it was plugged at the hose connection on the diff, cleaned that out and no more rear diff leaks. i know my tranny is on its way out but will see how much further it will go
6 speed or 8speed?
On 1/2/2022 at 7:46 AM, NWI Denali said:
OP, how many trans fluid changes? At what mileage did you replace shocks?
I replaced factory fill at somewhere around 15k.  Something just didn't feel right and have replaced with brand new fluid every 30k +/- a few k.  The wire harness in trans that read Temp failed.  I put new shocks all around probably around 30k with Bilsteins and actually think it's time to replace again but that was 4qty for under 400.00 and that ain't happening again....LOL probably more like 1k now because I want the all in ones with springs.
This is the 8speed as stated in post and honestly it's finicky loves HIGH/TEMPS and high torque!  Lug the trans and it will ride like ******!  Smash the peddle and it's quick and smooth.  It's 100% dependent on the intake and GM 8-pin MASS with humidity or any relative humidity in the air!  Change anything on the 8L90 that effects temp and ECU readings and it shifts like ******!
Trust me put in a different T-Stat to affect the time to operating temperature which you may never get to in higher latitude areas during winter driving even after 1hr+ driving?  Everything is catalogued and documented on this fine,fine automobile.
It likes to run HOT,HOT and that's just what it was engineered for I guess?  I am going to change the starter in couple weeks because I am about closing in on 7K starts and I think it's about time.
I also have a fine, fine report card @150K on used oil analysis and it's such a stud I think I am going to keep it for another 50-250K?
Edited by mookdoc6
On 1/1/2022 at 10:16 PM, Grumpy Bear said:
Oh boy are you lucky. Pepper is in her seasonal down time at 151,556 miles and still without issue. 😉 Luke cracked 20K some months ago. Popped in. Popped out and like smoke....gone again. :crackup:
Yeah...let me clean it first!
  • Haha 1
It's always great to see positive threads like this! 🙂
Clocking in at about 109k so I'm not quite that high in mileage yet, however I just fixed my first mechanical issue of the year with the manifold bolts (prior to getting that fixed the truck was driving kinda bad for a while), got on the highway for the first time since that repair, and HOLLLYYY crap it surprised the hell out of me.
This truck is almost 8 years old with almost 110k miles and it genuinely surprised me with its power and smooth shifting.  Isn't that something?
Oh by the way, also AFM enabled, bone stock, only difference is I have the 6-speed. 😉
WHAT??? Your not taking care of my truck? Well I never..............
:rollin:
It's a damn good reliable truck if you keep the upkeep on it.  I could put some electrical tape on odometer and with a damn near perfectly complected interior the occupant would never believe the mileage.  The reason I drive GM's is pretty simple cost of maintenance, parts procurement and longevity.
SO...ya are taking care of my truck. Good!
It must me photo shy 😉
AC thermostat for our Suburban was $35 on Amazon.  From what I found out after the fact, you can change the actual thermostat and not have to get the entire housing.
1 hour ago, silveradosid said:
do you have a part number for just the thermostat
GM Genuine Parts 15-11125 Water Pump Outlet Assembly with Thermostat
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
