I was surprised the Fiero didn’t stay around. My wife had two. And 84 and 86GT V-6. Her first toys. The 86 was actually quite fun.
Way to many headaches with the motors back then. Weren’t they called the “iron duke”   Many had issues with catching on fire.
When I was in elementary school a high schooler had a maroon GT Fiero, and I remember playing on the playground and watching that thing drive by. Man was it a sweet ride. Reminded me of a Ferrari. Because every kid back then had a picture in his bedroom of a red Ferrari Testerosa like the one in Magnum PI.   🤣👍
The first one a 4 cylinder was the iron duke. I remember them being pretty tough. The second was I believe a 2.8 V-6. I remember seeing V-8 conversion for those. We had the GT for awhile. They both were trouble free. A remember reading articles about GM finally got it right with the GT but too little, too late. I was pretty hands on back then so I was always checking it out. My wife’s main ride back  then was a 74 impala I modified with a 454, 700R4, 373. So we didn’t think of those as fast. I guess anything can be a fire hazard if not taken care of. A little oil leak in that small space, I can see it. I ended giving the GT to my daughter for college. She drove it through college, getting married until the little one came along. A 94 impala ss took its spot.
If they just could have found a way to put a TPI 305 in it. Thing would have scooted!  But then again it would have probably taken sales away from the camaro and corvette. Who knows but I’m a guy who’s all in and if you are going to do something. Do it to its fullest!!!  Could have been a bad@ss performing car as well as bad@ss looking car.
The fire issue was due to a typo in the service manual stating it only took 3 quarts.  Apparently some people were too stupid to check the oil dip stick back then.
Edited by Transient
Look up Fiero Formula.  Also, nothing could be faster than the Corvette.  Fiero was so small and light that it definitely could've destroyed a Corvette with the correct powertrain.
2 hours ago, Transient said:
668hp/659tq
I’m saying 755hp/755tq.  Read another article that states Cadillac is going big on this engine. I believe the reason they didn’t show numbers is because an LT5 is under the hood. If this is true, I already talked to the wife and if it’s right at $100k. I might pull the trigger. But if it’s above $125k. Then heck no!!
I have a hard time believing its getting LT5 but man would that be something.  Price wise is interesting take here.
The X5 M Comp starts around 106K while the X7 starts at 100k . LOL what a bargain compared to the -->The Benz GLS 63 which starts around 130k .  I would imagine it will 125k is obtainable ( with the LT4) With LT5 I'm thinking more.  I mean the ZR1's were around 120k right ?
Article I read gave the numbers I posted.  That's why I posted that.
Interesting. What article was that?  Motortrend and car and driver both said nothing. They did say the CT5 has the black wing motor with 668/659 but they aren’t for sure it’s that’s going in the Escalade.
I'll have to see if I can find it.  It was one of those recommended articles you get from Google when you open a new page and have Google as your homepage.
I thought BlackWing was the name of the 4.2 TT motor ?
And WTF happened to that motor?
It was, and they scraped it. Damn Shame :shakehead:
Imo they're taking that tech/what they learned, and are applying it to the Zr1. What's the engine designation, Lt6?
There's going to be way to many power train options for the corvette.
Lt2
Lt5
Lt6
Potential hybrid lt2, hybrid Lt6, full electric version...
Edited by M1ck3y
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
