I bought a used 2001 sierra slt 4x4 that was reprogrammed with a hypertech program. It wasn't done right on setup but I don't have the scanner tool that was originally used. My question is can I buy another programmer like sct or others and just start over ?
I think you would have to reset it back to factory settings (which would require the hypertech programmer)
That's my problem,  when I bought the truck there was no programmer.  Thanks
Without that programmer, the only thing you can do is have the ECU wiped and reprogrammed at a shop or mobile programmer that has a J-box. It's costs to get the required info from GM's website, plus the persons time, so you'll be into it for at least $200 I figure. Might be cheaper in AZ.
Either that or grab another one out of the boneyard (which might require programming anyway to get certain options to work), or, find one of those guys on eBay that'll sell you a used ECU, and they'll program your VIN and options into it prior to shipping it out.
What exactly was done wrong? Wrong axle ratio? That's about the only thing that'll screw up drivability with a Hypertech. Those things are so easy to use, a 4 year old could do it.
Edited by Jsdirt
The transmission shift points are way off and it hits Rev limiter causing it to cut out. I'm not sure what parameters everything is set for.
Gotcha. They set the shift points way too high. On a stock engine, they should be set at 5,500 RPM.
Mine shifted there with the stock trans. With the modified trans I now have it shifts around 5,300 or so.
I would e-mail hypertech and seek their advice. I’ve had hand helds on my truck since they were available. Probably all the brands. They all stored the original program and added theirs. Before I spent any money I’d email them.
On WOT it is cutting out at 6000 and I don't like those results if you know what I mean....lol
It says right in the directions that they can't help you without the original programmer, if I remember right. I'll take a look at it again in a bit here.
I will try that. Thanks
You need the actual unit in order to return the computer to stock. Without it, your only option is to reprogram your existing computer at a garage, or tuner shop.
https://postimg.cc/CZjf2FkY
I use to program to the redline then back a-bit I believe 5900. Then 50 percent TM and their premium engine tune. I can’t imagine a can tune jacking up that bad as he described. Unless a drastic tire size change?
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
