I have a 2013 silverado and the front wheels lock up in 4x4 but work fine in 2wd i dont have a any codes or light on or anything, soon as i put it in 4x4 and go forward they lock up and im not sure why?!
I would start with trying to narrow down where the binding is occurring. Put the truck in 4wd, Jack it up so all the tires are off the ground and see what happens. Maybe remove the front driveshaft see if it makes a difference.
Has it always done this? Tire size uniform? Are the front and rear differential ratios the same?
agreed, theres only 2 things that it could be, front differential or transfer case. put it in 4wd trans neutral ,disconnect the front drive shaft and see which end of the driveshaft you can't turn. front wheels off the ground of course. then get back to us.
"Lock up" on a hard surface as in bind or don't move ?
  • Confused 1
thinkn about it you will need all wheels off the ground to check it. transfer case failure is more likely and far easier repair than front diff
    • Still $3.01 with even more places at this price
    • JW2024 and Others is this site for Oshawa built Trucks as well ? Thank You !
    • Thanks JR that would be great if you could do that !!! Do you have a link to where this was discussed before ? I cant seem to find it  Thank You Again !
    • Oil pump noise was discussed before.  I will try to remember to record a remote start later this morning.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
