2 minutes ago, shakenfake said:
Regret when you just spent $$$ on a system you don't like and then do it all over again. Best practice is just weld a different muffler in imo
Not in NY, no way.  You chop and weld some crap in there, say goodbye to that muffler and the rest of the factory system in a couple years.
Plus I leave the factory system in the basement so if/when I sell, I set them back to stock and sell the catback for whatever I can get for it.
So how do you think the factory puts the muffler on? You think they just magically cast it together or....?
Not to be a nuisance but that means either a) the welds are trash or b) you didn't take care of it. Most likely a
Edited by shakenfake
3 hours ago, newdude said:
Open long tube headers or GTFO.  You won't ever have to worry about tips again!
HA! I played around with a 13 Camaro SS and ran open headers for a day or two. That was crazy loud. It did sound a bit nasty too. I just had the muffler and flapper cut on my 21 Sierra. Sounds pretty good just doing that. Ill probably leave it that way til the warranty runs out then throw LTHs on it. Personally I dont mind loud but it has to sound nice and clean.
I had a Dakota R/T back in the day when 250hp was a lot.  I had a set of Mopar Performance headers on it through two 40-series Flowmasters with cats I gutted with a long screwdriver.  Turned down the pipes right behind the mufflers.  Nobody cared about tips back then....the norm was to hide them...all about the sound...I couldn't have fit tips under it anyway....that thing was only a couple inches off the ground.....ahhh good times....
But now I'm a grown adult and I enjoy the civility and peacefulness of a quiet driving experience....😂
  • Haha 1
Honestly?  Its your truck.  Do whatever you want to it and don't ask or care what others think.
Also, this is why I stick to simple cat back exhausts that are quality and sound great like my Corsa Sport or a Borla, MBRP, Magnaflow, etc.  No ghetto 8 inch tips, no hacking, welding, regrets, etc.
Yes long tube headers just thats it would sound good 😂. Im thinking about 10” tips
They're another way you could also add more noise.  Replace the rubber bushings in your motor mounts with polyurethane bushings.  Fairly cheap mod.  All you need it access to a press.
For some reason lapoolboy's post reminded me of this mod.
Edited by Transient
Are you gonna squat the truck or what?
When are you gonna get that big ass antenna with the tennis balls on it?
Quit screwing around.
You know you're goin' here....
With an electric operated cap you'll be golden.
Pypes Performance Exhaust YVX10S - Pypes Stainless Steel Y Exhaust Cutouts
Tennis ball?  How about a 76 ball or Jack In The Box clown head?
@Transientfor the squatted truck community the tennis balls on the antenna represent how many girls they have slept with. I really think it means how many boys but I don't make the rules I just relay them
  • Haha 1
On 1/22/2022 at 7:25 PM, Avery Dameron said:
Haha yes!  The diameter 8”. They will be tucked up under the bumper mostly so only the edge will be visible. The pinched inside look like this.
Don't forget the truck nuts to complete the look!
And the bonus is that nobody will be able to put bananas in your tailpipe.  They'll need Grapefruit or Cantelope!!!
And my recommendation for the best exhaust sound is to route it directly into the cab of the truck.  That will give you the best sound and not piss off your neighbors too much.
😂 Well done sir!  Hopefully this kid isn't that gullible.
  • Haha 1
Yes. Ended up ordering 10” diameter rolled edge.
Hopefully this kid isnt as retarded as yall think. That deep tone is amazing
Thank god it wasn't the pinched tips
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
