So I'm wondering how much it will cost to add a sunroof a lift that won't kill my warranty and also an exhaust that won't kill my warranty... I can remember asking the finance guy about it when I got it back in April 2020... his answer was any mod would kill my factory and extended lds warranty.. is this true? Or what builds would be covered.
It is all dependent on the dealer you use. Some will let you get away with the mods listed and honor a warranty. It also depends on the type/amount of warranty work the dealership/manufacturer is willing to cover.
GM has an exhaust, this should at least be covered. It may be covered if the dealerships installs, might not be if you DIY.
Add the 2" GM lift to your truck and your warranty stays intact regardless of what a dealer tries to tell you.  Add the GM exhaust and again, your warranty stays intact regardless of what a dealer tries to tell you.  Basically, adding almost any factory offered aftermarket components designed and sold by GM will not void your warranty.
Sounds like you need an LT Trail Boss with a sunroof.  Adding a roof ain't cheap, possibility for leaks are endless with an aftermarket roof.
18 hours ago, AirForceAngler said:
There are only two kinds of sunroofs.  Those that leak, and those that are going to leak.
With GM, you apply that same logic to the sliding rear window :)
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
