Hello everyone,
I have a 2017 Silverado 1500 LT Z71 with a leveling kit and 33x12 wheels.
So I've been dealing with the problem of my truck shutting off when parallel parking and for the first time it shut off while making a right turn after a stop. Sometimes I'll start my truck and the problem will happen. In each of these times the "service stabilitrak" message comes on and my steering wheel flings to center itself and my truck shuts off. It has always started right back up after a few minutes. I also have a steering assist is reduced message but my steering has been feeling perfectly fine. I've been researching this problem for a while now and so far I have:
checked the ground under the dash (G218) and there was no insulation present there ( i believe GM fixed this problem).
I cleaned the ground behind the passenger wheel and even went as far as to change the entire negative cable.
My ABS wiring was messed up from rubbing on the control arm which i fixed as well and no longer rubs.
Even though i dont have a check engine light on i ran a scan and the code P10E4 came up as a possible issue, but after work i ran the scan again and the code disappeared without clearing it or anything.
If anyone has some type of advice or direction it would be greatly appreciated!
I am having the exact same issue at the moment! It started about 2-3 weeks ago and is happening more and more often. I’ve checked all the grounds as well and haven’t come up with anything.
Even just a week after I bought my new 2017 Silverado 3500 WT I began having those problems and I pulled the fuses for ABS and traction control. I know that seems weird and I’m not saying you should do this but I grew up racing and never liked those features anyways. I tow a lot and this forced me to get a aftermarket trailer brake controller. This actually works much better than the stock one. Happier all around and I never had to deal with the dealership hassle that I read so many people have had to deal with over the years. Good luck, it is a GM issue that maybe or maybe not they can fix for you.
Search the forums for "PIT5405".  This instruction covers the G218 ground but also other points to check (like starter connection, battery cables, etc).
look into your Evap system, sometimes raw fuel gets into the system (sometime when trying to top off the fuel tank) and floods the intake, especially when turning, and at low RPMs stalls the engine, it happens to my son's Ram truck w/Hemi
I have same problem 2017 AT 6.2
shut off  while driving once  !!! Bot truck new just started this winter 55k
checked all the grounds neg battery cable etcetc all the known causes
Dealer had truck for 2 days could not find issue and truck never shut  off when they had  it
in my case only happened in very cold weather but truck fully warmed up
when it shuts off cranks and fires but shuts off immediately
let it sit for 10-15 minutes starts and runs fine ??
when dealer had it it showed my low pressure fuel pump was getting weak intermiitently
they “ think “ the pump getting hot and pressure drops truck shuts off
when let sit  for a while pump cools then it starts ???
Thats odd because my truck only does this when the weather is warmer out. This happened a few times last summer but the problem went away once i cleaned the ground behind the passenger wheel. All through the winter it was fine up until we had a few nicer days then the problem came back
So i finally decided to take my truck into the dealer and they checked it out and told me the software was very outdated on a lot of things...cant remember what specifically, but i get my truck back tomorrow and will come back to you guys if the problem is still there.
What software ECM or BCM would be good  to know
Edited by CDNSS
Voltage drop both battery cables, anything over half volt and they should be replaced. An extremely common problem on those trucks. We change a lot of them at work.
It says the updated my power steering control module software. So far everything has been working good.
  • 2 years later...
2017 Silverado
My truck is trying to kill me!!!
Shuts off when turning at low speeds...like when turning left at busy intersection. I reported issue to transportation board of Canada because GM wont do sh*t.
"Like a Rock" Yes, like a rock indeed, I guess that means it sinks your bank account like one!!!
160000 kms or 100000 mi:
Transmission rebult...$7400.00
AC condenser leaking - bad wield  $1200.00
Crazy electrical problem - truck shuts off completely..dead... engine, radio all electrical. $ ???? Chasing this one myself
electrician by trade.
No recalls here in Canada for any of these issues... got to love GM...like a rock they said...
GM is aware of all of these problems because they have mostly been recalled in US but here in Canada we are too nice.
Sorry to bother you, but my truck that I bought new from you is a piece of SH*T
    • Thought I would add to what Bruce answered, not only do the HD models use the torsion bar system, there are I believe 5 different torsion bar spring ratings that are all physically interchangeable with all the HD trucks going from a two wheel drive 2500 all the way up to the duramax or a gas engine truck with a snow plow prep package front end weight capacity that use the maximum sized torsion bar. It starts from a 4400 lb rated set in 400 lb increments up to 6000 lb. If one wants to fine tune the ride for a certain truck application they can swap out the torsion bars.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
