Just now, 6.2ZR2 said:
Did they replace the collision alert camera?
That is what fixed mine, the unit up in the mirror.
Yes. Didn't fix mine. They said that they can't erase the fault codes so maybe that's the reason it's not enabling the features. I'm sure they'll figure it out on Monday.
I know when they did mine it took them a long time to get it reset and properly calibrated. They had to drive it almost 50 miles to finally get it.
Good luck and I hope they get it fixed.
Interesting... They drove mine for 4 miles only... Checked in with 9202m and it left the shop with 9206. 🤔
The second time it happened was just a day after I got it back. When I pulled the fuse, I can see tool marks on the fuse spade, so it had been pulled a few times before I looked at it. And yes, it can be the fuse. If the space tolerances are off, it will briefly lose power to those devices and throw a code. By pulling the fuse and repeating, you're essentially resetting the devices and clearing the code. I have a code reader and can see there are no codes. If the camera is defective, it wouldn't work intermittently, unless it's losing power. As far as the dealership is concerned, never trust these people. I had a 2015 Jeep Wrangler Ruby that would throw a check engine code if you were on a steep incline traveling at a 65 mph and it pops into passing gear. Long story short, they replaced the heads on the jeep and did a few other things that was simply absurd. I spoke with the mechanic and asked why would he do all that work, when it's nothing more than the ECM that needs a software update. He said that Chrysler, who owned Jeepbat that time, instructed them to do work sobthat the customer would think they were at least doing something. My grandfather was a master mechanic for Ford, so these are tactics used to make the customer happy to a certain extent. Don't trust these guys, they get paid every time you bring the truck in and make money off warranties. I'm about to make another trip to San Francisco, so if something happenes, it'll happen on this trip.
It works on the 2022's refresh?
The reason I ask is when I got my ZR2 I hooked our scanners up which work previous models doesn't communicate with it.
We were told GM has changed everything with the refresh and hasn't started releasing it yet.
If there is something out there I would like to know.
Unfortunately, I am having the same issue with my 2022 Silverado LTZ Z71.  Amber Front Collision light is on and LKA will not turn on.  Will try the fuse option and let you know what happens.
Just left dealer and they said it was “cornea”/camera and are trying to figure out part number to replace and then order. Hope this is the fix
From the experience of others on this post, it continues to happen. At the moment, there isn't a recall for the fuse block, which is what I believe to be the issue. After tweeking the a couple of the spades on the fuse itself, I've not experiences any issues. It happened 3 times prior and one of those times was just a day out of the shop. I'm not going to allow them to replace anything until we get the missing chips. They get paid by GM every time you take it in. Doesn't matter if it fixes anything or not. Even the guy you check in with at the dealer makes commissions from it. Don't trust them at all!
Didn't work for me so heading to dealer soon.
Well as it turns out there was an error in the calibration the first time they did it… a different tech recalibrated it today and it works fine.
Yeah yeah, I’m on my way to get gas 🤣9344E00B-6ACA-477F-B5FA-2625BB8E63E2.thumb.jpeg.d6ebc07568d603d7723fa3e921b5eb6b.jpeg
Pull it and prior to putting it back, slightly bend 2 of the 3 spades so it makes a tight fit. The metal expands with heat and contracts with cooler temps. I think this is what's causing the issue.
Keep us posted!
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
