Hello.
I have a 2020 2500hd duramax with 16000 miles. On highway not towing I can get between 19-21 mpg.  But when towing our travel trailer which weighs about 9000# the very best I have ever got on highway is 10.2.  Does this sound right?  A guy with same truck at campground says he gets about 13 mpg and he’s pulling a 5th wheel.
thx for any help
Edited by MikeZ65
57 minutes ago, MikeZ65 said:
Hello.
thx for any help
Speed is the killer of MPG when towing. I've found that if I don't try keeping up with traffic I average 12-14 mpg on the highway towing my travel trailer of about the same weight. The worst mileage I've had was towing through the mountains and that was still 10-11 mpg. If you are relying upon your truck's display for MPG average, you might try hand calculating to see if it's just too far off. Something else to consider is how you have your rig setup. The travel trailer should set level as possible while towing. Check tire pressures on truck and trailer, low pressure can lead to poor MPG. Tire or suspension modifications definitely, such as a lift/level can set you back too. I remember replacing my truck tires with a lot more aggressive tread and I dropped about 1 MPG.
Thanks. Most I will do is speed limit but more times than not I am 5 or so below. Stock ltz no mods. I do sometimes wonder if it ever finds final gear. Is there a way to tell what gear the truck is in while going down road.  10mpg just seems low for flat Florida    Thx again
I've towed my 30' Airstream to the west coast and back from Ohio, 6,500 miles total, and averaged 13.4 mpg.  That's legitimate hand calculated mileage.  The trailer weights about 8,400 lbs loaded.  I have a Banks iDash and it displays the active gear, which is the only way I know with a GMC or Sierra to tell the gear.  It seems counter intuitive but I find I get the best mileage when the truck is in 10th gear.  At 60 or 62 in tow/haul mode the truck stays in 9th gear most of the time.  If I speed up to 68 or 69 the truck will shift to 10th and mileage goes up a smidge.  Normally, I would swear that you'd always get better mileage at a lower speed but this truck is different than others I've had.  I can only attribute it to the 10 speed transmission with it's three overdrive gears.  Fords and Rams will display the trans gear on the dash - not sure why GM doesn't.  It's really nice to know what gear the truck is in at any given time.
This is my experience and others will have different results.  Wind speed, wind direction, altitude as well as the weather are also factors that can affect mileage in different ways.  Size, weight and shape of the trailer also play a huge part in fuel mileage.
Edited by unit
Added info.
My first tow with a 5er of similar weight last month was over a mountain pass in WA.  Got 12 MPG on the trip (hand calculated). Speed limit was 70 a lot of the way, but kept the cruise at 5 over the posted truck speed of 60. Got passed left and right, but did not care. With the price of diesel what it is, no big hurry! I get what you do without towing, got 4k on the clock.
I need to look into the banks idash.  I really would like to know what gear it is in. As mentioned with price of diesel I need every mpg I can get.
Average seems to be about 13 mpg for me when in tow haul mode no matter what I am pulling.  I have not really loaded it down heavy, heaviest loads I have had on the truck has been my 22ft equipment trailer and 4 large bales of hay, probably somewhere between 9,000-10,000 lbs loaded trailer.  I get average about 18 mpg with mixed driving.  Those figures are from the trucks computer, I have not hand calculated.
I have a 21 GMC Denali 3500 Long bed SRW. Truck has just over 15K miles. I tow a 42" 5th wheel that weighs right at 14K. Granted I have yet to tow any real distance (most trips were 1 hour or less) my average towing is 8.5.
With a lot of headwinds out West I tend to get only 5-7 MPG if I am lucky. It’s sucks having only a 36 gallon tank. In perfect, level conditions I might get 10 MPG with my 36’ 5th wheel.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
