4 hours ago, mjonesjr84 said:
The dash speakers are super easy in the refresh compared to the 19-21 trucks.
In my 2022 refresh with Bose, the front door speakers are 2 ohm while the dash and rear doors are 4 ohm.
If replacing your dash speakers, there isn't a wiring adapter available. The driver side + wire is the blue with purple stripe. The passenger side+ wire is the white with yellow stripe. I used the PAC BB-2PR 600hz at 4 ohm bass blockers on the dash speakers.
To get to the dash speakers in a refresh interior, both A-pillar trims have to come off, then the speaker trim will pop up. The grills are connected to each other by the panel all across the dash. It pops up really easy. The HUD or Driver Alert trim comes off with it. There is enough wire that you don't have to unplug the Driver Alert light. See the picture for reference.
Just an FYI for those interested.
That's good info and taking the leap. If possible maybe taking a sound clip of before and after new dash speakers.  Did you do the doors too?
I didn't take any sound samples. It would be hard to tell on a cell phone video anyway.
I did do the doors. I did Kicker in there as well. I've got a pair of PowerBass 2ohm DVC 6x9's coming to see if the front doors sound better vs the 4 ohm Kickers. I've also got baffles coming as well for all the doors. That should make a difference as well since they have cones on them to get the sound directed towards the door panel grill instead of letting sound filter out behind the door panel.
The dash speakers had the + marked on them so it was just a matter of plugging the wire clip back in and seeing which wire was on the + side. I left enough wire on the factory plug so I could go back to it if I wanted to put the factory speakers back in.
The only down side to the bass blockers is the turn signal sound is quieter than without. I may take the blockers out to see what it sounds like without them.
Which door baffles did you get and can you post a link? Also which Kicker 6x9 door and dash tweeters did you use? Did you have the Bose system?
I went with these baffles front and back.
NVX XBAF65 Foldable Silicone 6.5" Speaker Baffle with Egg Crate Foam, one Pair/Box https://a.co/d/5xKRqMw
I used the Kicker KS Series so far in all 3 locations (6x9 in front door, 6.5 in rear door, and 2.75 in dash). The dash speakers came with the plates to mount them.
I also went with these rear door adapters. They are a lot sturdier than the ones Crutchfield sent. They also move the speaker out closer to the door panel.
RED WOLF Front/Rear Door 6.5" Inch Aftermarket Speaker Update Install Speaker Adapter Bracket Spacers for Chevrolet 2006-2021, GMC 2006-2020, Some Cadillac, Buick, Pontiac https://a.co/d/7pDReV6
I do have a pair of PowerBass 6x9's coming to try in the front doors. They are a dual voice coil that can be wired to require 2 ohms from the amp. Since the front door speakers were 2 ohm, I'm hoping these help with the sound. The Kicker 6x9's sound better than the OEM speakers, but still not what I'm expecting. I know my expectations shouldn't be high without adding an amp, but our 2020 Equinox factory Bose system rocks (granted the Equinox is a 7 speaker system). If I can get the truck close I'll be happy.
Thanks for the info. Yea I wondered if using 4ohm speakers would lower the volume. I don't know of any 2 ohm 6x9's. Did the dash tweeters make a big difference?
The PowerBass 6x9's I've got coming today are 2 ohm. They have dual voice could that are 4 ohm each. They can be wired to 2 or 8 ohm depending on how you wire the voice coils together. I'll update how they are later today when I get them installed.
4 ohm speakers will lower the volume when the amp is looking for 2 ohm. It is weird that the other speakers are 4 ohm but the front door speakers are 2.
Yea, the dash speakers made a huge difference. The only drawback is the dash chimes (turn signals, etc) are lower. I think that has to do with the bass blockers I installed.
Edited by mjonesjr84
I did install Rockford Fosgate R169X2in front door,  Memphis Audio PRX27 in dash & R1675X2 in the rear doors, still with stock radio.
Sound did improved a lot, bought it from Crutchfield.com
I looked at the Power Bass 6x9. Says the 2 way fits but not the 3 way. That's weird... Both are 2 ohm. Did you order the 2 or 3 way? Do you have Bose or standard sound in your truck?
I got these.
Powerbass OE-690D 6x9 Midbass OEM Replacement Speakers/Woofers (Pair) https://a.co/d/aeT4H3U
I've got the Bose system in my truck.
54 minutes ago, mjonesjr84 said:
I got these.
Great. Anxious to see how this setup sounds. Keep me posted please.
I installed the PowerBass speakers and ran them for a day. They sounded just ok. They almost had the same sound as the OEM speakers. They wouldn't fit with the baffles under the door panel. The PowerBass speakers specifically say in the instructions "Do not use with aftermarket amp". They also only have about 1/2 the RMS power handling that the Kickers have.
I wound up going back to the Kickers with the baffles. My plan changed a bit and probably next month I'll add an amp to power the door speakers so I get the full sound from them. I'll just have to keep in mind the volume will be a little louder until I add the amp.
Wow... thanks for the pics and the update. Was hoping for a better outcome on the PBbusing the 2 ohm jumpers.  Is the OEM front door speakers mid bass or 2 way? Can you hear the tweeters on the Kickers or are there factory Bose high frequency blockers? So the Kickers sound better but just not as loud because of being 4 ohm?  Maybe a low ohm 2 or 3 way would sound better.  PB has a 2 ohm 2 and 3 way which may sound better than the mid bass speaker.  Have you done anything with the rear doors? I think those are 4 ohm. I wonder if changing them to 2 ohm would help?
Not going to say the Kicker's sound better, but there wasn't much difference with the PowerBass speakers. For the cost difference, I'll go with the Kicker's and add an amp to make them really sound better.
I did replace the rear door speakers with 6.5" Kickers. All 6 speakers in the truck match. The rears made a difference over the OEM ones. There was even more difference when I went with the baffles. The OEM rear and dash speakers are 4 ohm. Crutchfield didn't send rear speaker adapters so I went with these instead of the adapters that came with the Kicker speakers. https://smile.amazon.com/dp/B0811YYTNY?psc=1&ref=ppx_yo2ov_dt_b_product_details They are much better built and move the speaker out closer to the door panel. With the baffles installed, there was a significant difference in sound from the rear speakers.
Gotcha. I see powebass makes a 2 ohm 6x9 in 2 or 3 way. Thinking that would make a difference in the front doors over the 4 ohm idk. You think 2 ohm speakers in rear doors would work instead of 4 ohm?
Would 2 ohm speakers in the rear door work? Probably. The OEM speakers are 4 ohm, so if you are going to replace them, why not go with 4 ohm so you have a wider variety of speakers?
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
