Ok  just trying to get a feel from people who have picked up their truck in the last 4-8 weeks.  Long story short have an order in for a truck that hasnt been picked up yet.  Fell into a truck at another dealer for a truck that is everything i want minus one thing.  As of yesterday it was at 3400 with a TPW of 11 JUL.  So I would guess that truck probably goes 3800 next week.
SO kind of playing two dealers right now.  the one on order not picked up will be a 23 but due to the potential 23 cost increase and the rumored 1500 onstar charge now, will probably cost 3-4k more than the 22 that I have my name on at the other dealer.
Anyways anyways kind of wondering what time frame people are seeing from 3800 to delivery.  Dealer is quoting 6-8 weeks,  normally in the past when I ordered it was 2-4 weeks.
To be upfront I value input but if you havent recevied a truck in the last month or two, your delivery time wont really be relevant to my situation.
Edited by nards444
My 22 that didnt get picked up will cost me $3700 more to re-order the exact same truck in a 23MY.  So your $3-$4k increase assesment is on point.
I was notified mine was 3400 on June 10th, 3800 June 18th, At the dealership July 7th.
Thanks. I order most vehicles and from the 3800 series it has always seems to be 2-4 weeks As of yesterday I went from 3400 to 3800.  I am expecting it here by mid August.
From what I  gather it’s the mandatory 1500 charge now. And the truck it’s self is around 2200 more give or take. So I think taking the 22 is the better option otherwise waiting for the 24 redesign
Eleven months from Order to pick up.
Six months sitting at Flint to delivery.
Ordered last June 2021, picked up May 2022.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
