These new modern engines use technology that is hard on engines and oil so the oil filter is a critical part of the system. You often hear the phase "Its cheap insurance" from 3,000 mile oil change enthusiasts,   So changing the filter is cheap insurance in my opinion.
OK Karnut, I will try to answer the OP's question without being condescending.
Try a different oil and filter. Change your OCI.
  • Haha 1
Oil filter going 6000 miles isn't going to be the reason for the whine......but I can't help myself and ask would you like some cheese with that whine? LOL
When you change the oil it's affecting something else that you are hearing and mitigates over the oil drain?
Some basic filter theory for those who care.
Liquid filters work by changing the direction of the fluid and " flicking off" the solids it can then hold. Liquid filters are most efficient when new.  Complete opposite of air filtration efficiency.
When auto makers initially considered oil filters especially full flow versions they mistook bypass filtration and air filter theories for full flow thus the advice to change oil filters every other oil change. Engineering groups with poor QC/QA didn't clean up the books or ignored the newer knowledge and left those suggestions in place.
Having said all that full flow filters are so inefficient it may not matter that much.
Long drain oil filters just have more capacity to hold large particles. They don't generally filter more finely or hold a lot of stuff. They just can live longer to a spec.  Its kinda odd thinking but 3 things matter in full flow, life, capacity and efficiency.
Bypass can filter a range and then allow almost anything outside of it to pass. A reason I don't run bypass filters.
Centrifugal filters will separate additive package out of engine oils if well made and high speed.....LOL
Your noise is related to the fresh oil vs used oil if noise abates after some time.
  • Haha 1
1 hour ago, Grumpy Bear said:
Would it change minds IF his OCI is 2K miles and he is using a premium 10-15K filter?
The Mob's answer is, NO!
Let the battle continue until there is a clear winner🤔😬😯
See the source image
  • Haha 3
There are not a lot of internal parts that can make a whining noise that would relate to new oil other than the oil pump
  • Thanks 1
Its hard without being able to hear the noise. Any chance it is a vacuum leak? Something get disturbed while working on it?
20 hours ago, 20silverado20 said:
It sat over night. I checked it before the oil change and was good on the dip stick. Thats why i put the exact amout that came out.   I didn't change the filter. I change it every other oil change.   Last time i changed it, it did the same thing. the filter was changed and it took right at 6 qts.
What is your oil drain interval that you leave the filter on there?
Hopefully OP gives a status since the pot is stirred up...inquiring minds want to know 👍.
Sorry, ive been on vacation.    It makes the whine when i change the filter also.  As for charging the filter every other time, its just something ive always done.. no real reason for it.   The whine sounds like a honda civic in reverse (if that makes sense) but a deeper sound.  It does it in neutral and while driving. No issues with the transmission.  It only does it when i change the oil.  The only thing i can think of is the oil pump.   The oil is Castrol gtx, and filter is ac delco if that matters
How often do you change the oil vs. the filter in terms of mileage?
Edited by newdude
2 hours ago, Grumpy Bear said:
I didn't hear anything in the video that sent up red flags. :dunno:
Its alot quieter now, after a week it starts to go away. U can barely hear the whining in the video. Its much louder after the oil change
I usually change the oil every 5,000-6,000. Its made the noise since the very first change. Oil and filter were changed.  It doesn't go away if i change the filter. Its the same exact noise every time, its never quieter or louder.   After about a week it quiets down, then goes away until the next oil change
If it has done this from the first oil change and there have been no motor problems what's the issue? Curiosity? As I said, I would change the oil more frequently and use a better oil filter. If your curious enough switch to better quality oil, Amsoil OE would be my choice.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,313 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
