I replaced the hinge bushings and pins and it made this much worse, I can stick my finger through the gap between the door and the cab itself, near the handle. The hinges look like they're welded to the chassis, so I'm wondering if anyone has any suggestions or knows how to fix this? The fender could definitely use some adjustment, but I'd rather adjust that after the door is adjusted.. I was considering 2 things, first being pulling the hinges with a hydraulic pulling ram, and the second was cutting some out of the hinge on the chassis, then folding it in, and welding it back.. both of those seem like guesswork with a lot of room for error. Surely there's a proper method to this?
If anyone else has this issue, I "fixed" it with the socket trick, putting a socket in the hinge and closing the door. Made the gap much smaller and it doesn't hit the fender now. Not perfect though, yet.
Socket or hammer in the hinge just bends the pillar on which the hinge is welded. I have never fooled with welded hinges much, They use some kind of registration method (a way to ensure the hinge is in the right place in space relative to the door and fender when it's welded in place) at the factory. A Mitchelle Body manual (for labor hours) may show some dimensioning (for the hinge) that shows where it goes. I wouldn't mess with it if I didn't have my own pro shop or weren't a pro.  I would be sure I got the right pins and bushings and they were in the right spot. On my 04 I have 2 different sizes. It could be you got a kit that was put together wrong. You don't say how the door performs when it closes, it's plain to see that gap on the trailing edge wow! How your door got so far forward is beyond me. I'm assuming the holes for the bushings were (are)still correct and not "wallered out" in anyway even if they are I can't see them doing their job at all noting the distance your door have moved forward relative to the door opening; seems to me the holes in the hinges would be completely worn though on the forward side of the bushing hole for your door to be that far forward. If your door/fender joint functioned correctly before the pin and bushing change that means the fender position is still correct unless the fender has been moved some how (accident, attempted adjustment?) Obviously you can't fix the aft door gap by adjusting the fender. I suppose it's possible the hinges got twisted (how I don't know)in such a way that the door is now too far forward relative to the door opening. I would make sure I got the right parts, after that maybe a door from a yard to compare. Are you the original owner? Has the truck been hit, in an accident? This makes no sense at all if all parts are genuine and correct, but if they were you shouldn't have the problem that you got.
You might try a "TRAM" (Trammel) gauge and compare opposite sides of the door opening, hinge placement and the door using the other door for reference. Would love to know what you learn, good luck my friend!
    • My take: I don't think seeing up to 200k on the odometer of any of these engines/trucks (2014-to present) is surprising. (Excluding the known DEFECTS, specifically, the 6.2 main/connecting rod bearing issues, the defective lifters, alternatively parts that a recall was issued for - I think there were three.)   250K is my line in the sand, anything over that is 'surprising', but not limited to the engine making it that far but including the truck surrounding it too. (We've talked about this in other posts, why I think the engine isn't the deciding factor for ultimate mileage.)
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
