Not sure how to message them directly but I have a question for them that we talked about previously:
How come there is no forum for the 2022 Refresh model?
Or for the 2023?
I believe it would be helpful to at least edit the current forum name and edit it to (2019-2023) or something similar.
 Thank you
Edited by Nestor Romero
Spelling
Or for the 2023?
 Thank you
Or for the 2023?
 Thank you
Or for the 2023?
 Thank you
If you want to start a thread it will be seen. If you state it’s a 2023 then I’m sure the year will be added eventually. I see plenty of refresh threads.
I understand that.
I can’t understand why not do it the proper way and have it organized.
way too many mix ups in the “2019-2021”   Come on I get 2022 the refresh blah blh blah but we are in 2023 now.
makes these forums seem neglected
besides all the ADS everywhere
11 hours ago, Nestor Romero said:
I understand that.
I would think the best way to go about adding a new sub forum would be to PM Zane who is the admin here, his account shows he was last active here right before christmas so maybe he would eventually see it and work on it, though im sure it has been mentioned to him before.
I agree though, i think the refresh deserve it's own sub forum at this point. The colorado/canyon section could use an update as well.
Thank you.
Not sure why it is so hard.
like asking congress to pass a reform 😂
WTH come on Zane!
14 hours ago, Nestor Romero said:
Thank you.
WTH come on Zane!
He is busy and when he created this forum he had a different life i'm sure, as this place has been around for awhile. Not sure mods can help on this, maybe one can chime in here if they see this. Like i said i think the best way would be to pm zane and please don't spam his mail box either, send a message and wait for a reply. Like i said he has not been on here for a few weeks now so it might take a bit to see it, give him some time and i'm sure he will answer back.
Mods don't have ability to modify forum. I've forwarded messages to Admins on this subject in the past and continue to do so
On 1/12/2023 at 6:18 PM, Nestor Romero said:
Thank you.
WTH come on Zane!
Many of us have tried to get this fixed for a couple of years. At this point, it appears that Zane is only interested in revenue streams--the incessant ads here, and telling everyone to view the youtube channel. Nothing else ever gets done. Txab is about the only active moderator--there used to be many.
I agree with you Bret as this site has been slowly going down for awhile. I think they have put this site out behind the tool shed.
Seems would be easy to just change it from 2019 - 2021 to 2019 - Present
Correct, but apparently this is too hard to do Tom or they are too busy to bother.
Doing so will positively impact users' experience and navigation through the forums, specially new subscribers.
Maybe if you look it says 2019-2023.
Edited by Silverado4x4
Yup and they added the new EV forum and updated the Colorado section, Thank you Mr. Zane or Mod that was given control of that power.👍
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
