Wife picked up a pair of these for Christmas and I like the looks of them. No instructions were included and even after contacting the seller, they were no help. My question is what is the best way to wire the LED strips? Would you guys hook these up to be the same as DRL? Looking for some suggestions. Thanks
I'm curious what Brand these are. Any name?  DNA!   my bad....Check & search youtube
Edited by rav3
Most aftermarkets are just plug and play.
Have you attempted the install yet?
I have not tried just yet The LED strip needs to be wired in with the housing
I'd have to see the headlight setup to advise further.
Generally, there will be a connection on the headlight assembly to connect the LED strip.
However, I'm not familiar with this set of headlights.
I don't have those headlights but added Putco Dayliner LED strips similar to them because I wanted that look.  On mine I kept all the stock wiring normal and added the LEDs on their own circuit.  If you search on here you can find a wiring diagram from the BCM.  I don't remember the pins but I wired them to ignition on, then replaced one of the cigarette lighter spots in the center console with a simple toggle switch (you wouldn't need to do this if you want them on all the time, I just wanted the ability to shut them off when sitting still with the truck running).
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
