On 1/25/2023 at 10:25 AM, Jettech1 said:
The diesel option in both the 2500/3500 give you the 12" rear diff.  But they both get the 11.5" when they are gassers from what I've read.  I could be wrong as I am most of the time...lol....
My understanding is the diesel 3500 has the larger rear differential, but not the diesel 2500. I am not positive this is correct though.
Edited by Another JR
Because I'm often wrong I thought I would dig in a bit and try to find the correct answer.  From my research the 11.5" (GT4) 3.73 rear end is used in both the 2500/3500 gassers.  The 12" (GU6) 3.42 rear end is used in the 2500/3500 diesels.  Just because of my research doesn't mean I'm 100% correct, it only means what I was able to find using a differential supplier website.
On 1/25/2023 at 12:25 PM, Jettech1 said:
The diesel option in both the 2500/3500 give you the 12" rear diff.  But they both get the 11.5" when they are gassers from what I've read.  I could be wrong as I am most of the time...lol.... And you're right about the payload capacities between the two.  The 3500's generally have about 500lb extra payload capacity due to the rear helper springs.  The overall spring pack is identical between them both.  I guess a 3500 gasser might be useful if you're more looking for payload capacities and not necessarily towing abilities. And that brings up one other option that I had to have and would totally recommend for anyone buying a HD truck, and that is the 5th wheel/gooseneck prep.  It's about a grand but gives you more options.  We probably will never buy a 5th wheel, but who knows, it's always nice to have the ability if needed.  To me that is the one option, even if you never use it, to always select or look for when buying a HD.
Usually I just install the B&W turnover ball but this 23 came with the factory prep package.  I personally don't like it.  I like the B&W better, but I don't own a fifth wheel either only gooseneck trailers.  I hate the fact you can turn the ball over and it seems to "rattle" (for lack of a better term) a lot more.  Plus I don't like the fact the ball sits up off the bed higher than the B&W.  But it is a nice deal that it's all setup when you get it and you don't have to drop it off and get it installed.
How will the ride compare between the gas/diesel.  It seems like the diesel might have a nicer ride given the additiuonal weight.  I was convinced I was giving the gas motor a shot but I'm starting to waffle again.  The dealer still has time to change my order.
17 hours ago, Another JR said:
Just as a data point:
The RGAWR on my 2021 3500 hd cclb srw gas truck is 7,250 lbs. The tires (stock Michelins on 18s) are rated at 3,640 lbs single at 80 psi, so the simple  tire limited axle limit would be 7,280 lbs.  My payload rating is 4,054 lbs, which I think is about 1,000 lbs more than a typical 2500hd.
My understanding from what MTU has posted is that, in addition to differences in the rear overload springs, the basic rear spring pack on the 3500 has one additional spring relative to the 2500.
My 21 CCSB Custom 2500hd gas had around 3480 of payload and my 22 CCSB LT 2500hd has around the same as far as payload. I wanted a 3500hd for the extra 600lb ish of payload but it was really hard to find my 2500hd and I couldn't find a 3500hd that had what I wanted.
Negligible difference I’m sure.
I wouldn’t let ride decide your diesel vs gas decision. Capability needs, purchase and maintenance cost, and reliability track record would be the drivers for me.
If you look at the chart for which torsion springs and front axle weight ratings apply to the various configurations, you can see they bump up the spring and the rating by 400 lbs for the diesel in a given body configuration. So the front of the diesel will be heavier, but the stiffness of the front suspension as loaded would be similar.
I can state for a fact that my 3500 gasser has 3.73 gears.
Yes, all gas are 3.73 and all diesel are 3.42. What we were discussing was whether all diesels have the larger ring gear diameter. Jettech1 is correct I believe that all diesels have the larger gear set. I just remembered that the difference between 2500 and 3500 gear set size (not ratio) I had seen in a video was for the pre-2020 gas models.
Correct, both of the gassers do.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • NewDude, thank you for the suggestions!    I did follow up and the dealer indicates he has an open CX case and is working with DPAC (Dealer Parts Assistance Center).   Per the dealer, GM has had a quality spill and is not providing an update for when a replacement engine will be available.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
