8 minutes ago, luke1333 said:
5100s here and Michelin LTX for summer wheels and the ride is like butter. 10x better then ranchos and the truck is actually stable over RR tracks or washboard areas. Sounds like your tires and inflation is off.
I am curious what the MultiMatic DSSV ride like though, heard nothing but good things about them
 Same tire/same pressures before an after. Deductive logic would indicate the shocks and their digressive damping would be the culprit.
Again. 5100s are NOT the shock to choose if you want a more comfortable ride. They are more stable, and less "floaty", yes. But not more comfortable.
That being said, it's a truck. It's not going to ride like an S-class regardless of shock choice.
I personally thought the truck road like a brick with tire pressures at manufacture recommended pressures no matter the shock combo. Very true if you want comfy ride you go get a yukon with air ride. Those just float on a cloud down the road!
It  is unfortunate that you purchased a truck with 20 inch wheels. Big wheels and short sidewalls give a hard ride. 20 inch wheels belong on sports cars. My Z71 with 18 inch wheels rides very well.
I have the 5100s on my rst with the 20 inch wheels and to me the ride is stiffer. I feel more road imperfections than with the ranchos but i think the handling is more stable imo. when i would go down the backroad I live on with the rachos it felt like the backend was getting a little loose. I dont have that with 5100s
I've been contemplating upgrading the shocks on my 2022 custom. I notice my rear end gets really squirrelly sometimes at highway speeds when i go over bumps. I was thinking Bilstein 5100's
On 2/2/2023 at 1:03 PM, Jus Cruisin said:
I've had a 2019 Ram Limited 4X4 then a 2021 F150 Platinum 4X4 and now a 2023 Denali Ultimate 4X4. The Ram had the best ride with the air suspension. The F150 had the worst (I think the light weight contributed). And the Denali is pretty close to the Ram. I have magnetic ride and it rides really smoothly even with the 22's.
Unless I missing something, I'pretty sure that, like my Denali, your shocks' valves are electronically controlled, but your do not have magnetic ride control, which used to involve electrically charged shock fluid.
Edited by MrLeadFoot
What kind of tires? Big wheels, less tire sidewall equals rough ride. My son's performance 18' wheels/tires are rough as hell...and noisy. When his 16' wheels are put on fro winter...smooth as hell. The brand makes a difference too. Before spending on shocks, it would be nice swap wheels and tires with another truck. The dealer should be able to do this as you're new truck is not right. As a lifelong mechanic, I was always amazed how certain brands of tires changed a vehicle ride completely.
Don't expect Bilstein shocks to improve your ride quality as they are very firm. The 20 inch tires are the issue. Replace them with the Z71 18 inch wheels and Michelin Defender tires.
Exactly!
On my 2014 LTZ Z71, I replaced the ranch’s with bilsteins and riding is stiffer but after years of riding on them, I am thinking of replacing it all with some fox shocks. I am wondering if anyone has any comments on this? Cheaper option is to use the fox 2.0 shocks or spend way more and get the fox 2,5 adjustable shocks. My repair shop is getting told that these shock’s don’t work as well in colder climates. I do ride on 20 but I think going with e expensive way is still cheaper than a new vehicle. The adjustments will allow me to change the ride and tons of new vehicle use the same shocks like fox and even the zr2 Colorado and Silverado so they must work in all climates.
I put the fox 2.0 on my 2020 Z71 and raised the front 2 inches and the back 1 1/2 with blocks. The floating feeling is gone and the truck is smoother on rough roads than it was with the ranchos. I have 20 inch wheels so the ride is still a little rough but much better than before. My friends that have full size trucks all comment on how much better mine rides than their truck. The highway multiple bouncy thing and actually rocking when sitting still and other cars went by was unbearable.
Edited by SilverMak
20's on my old '11 Tahoe w/electronic shocks, not magna, and it rode good with the factory 20's. Not AT or LT tires though and that's the difference.
20's on my LTZ Z71 but those stock tires are not LT's or beefy AT tires so it rides good for a light in the rear pickup.
20's on my Traverse High Country and it rides great.
There is more to it other than just the 20's. Sidewall height and flex are the big part of it also.
Edited by repairman54
none
Any suggestions for a better suspension ride. I guess struts and shocks on a 2019 chevy silverado custom.  Leveled. No lift kit but 33x12.5x20 tires
Offset -13
On 1/30/2023 at 7:10 AM, newdude said:
Put 200lbs in the bed.  Its a truck.  Empty ride is never as soft as a ride with a load.
Soft my ass 😆 My truck rear bounces like a hoopty when pulling my boat. Its not even that heavy-3K lbs.
On 1/30/2023 at 2:03 PM, asilverblazer said:
The Bilstein shock absorbers are valved slightly more aggressively than factory to more aggressively dampen suspension motions.
This can do two things. An impact from a bump might feel more severe initially because a more aggressive shock absorber won't allow the suspension to compress as much or as quickly. This impact will get transferred to the passenger compartment - you.
Second, there will be less bounces from the same impact. While the initial impact might seem more severe, there will be fewer subsequent bounces, because the shock absorber already limited or slowed the motion.
These two conditions make describing the effects of the shocks confusing. The ride may seem rougher from the impact but also less bouncy at the same time or smoother... Each individual will have different preferences to these two sensations.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
