Did a search, but wasnt any real one stop reviewing that I found. Was looking at the next project (just installed 5100s) and was looking at picking up some anti sway bars. Have a 2020 RST/4wd so would be looking to do both. Some info on the hellwigs but its over 1K for both. Found the belltech which look similar and found for about $650. I dont do a ton of towing but lots of spirited highway driving to work.
Looking for some input if anyone has gone this route or think it was a waste to install period
Big waste of money.
  • Sad 1
13 hours ago, Silverado4x4 said:
Big waste of money.
COMPLETE LIE!!!  I installed bigger swaybars on my 05 Dodge Magnum RT. Had stock suspension otherwise with 75K miles on it. It had front and rear sway bars but they were small. Put the Petty Garage sway bars on it and it was INSANE how much better it made it handle at stock height! I always thought lowering was what made a vehicle handle better. I had never upgraded sway bars until then. I want to put at least a rear bar on my Trail Boss but haven't decided if I'm going to go with just a rear Helwig bar or go with the Belltech pair.
I did both front and rear hellwigs on my 2021 RST 6.2. It handles turns/corners much better. Was it worth the cost? depends on you goals. For me it was. After i added the hellwigs, i got the beltech drop coilovers up front along with a regular set of Bilstein yellow monotubes in the back, its way better than stock handling ever was. Much sportier and controlled in all driving aspects. If worried about costs, try the rear bar 1st. It made more of a difference on previous trucks ive added them to. This time i did both at the same time so i cant compare just the rear with stock front bar.
  • Like 3
Do what dram mentioned above and try the rear first. You will notice a big difference in the handling at high and low speeds. I have the Hellwig bar on the rear and stock on the front and I'm still happy the the purchase.
Ironically that's what I was kinda thinking. Spending a bit more on the rear and grabbing a stock front from eBay with links.
But wasn't sure about removing all doubts and grabbing the belltech and calling it a day
Most of what Ive read people consistently mentioning it tightening everything up. Esp if you upgraded to the Bilsteins
But everyone agrees get the rear bar first?
Correct
I would put the suspension components(front springs and four shocks) you want on there first and see if that takes care of your issue.  Replacing shocks and front springs on my truck created a world of difference in hauling a boat and tractor around, particularly in body roll and bounce.
Alraady have the bilstein 5100 front and rear. Pretty decent improvement but still wanting to tighten her up.
I'm not in a rush so will keep my eyes open for deals.
Dram.. I appreciate your constructive inputs man.
i emailed hellwig and they said the same ones will fit my 23 rst but their website only lists up to 21 at this time weird...
Nothing was changed on the rears of the trucks, just the front and interior. Usually they don't update their websites or fitment until they have confirmed it themselves.
  • 3 weeks later...
I have been considering a rear bar for my 21RST, The Hellwig 7780 seems like the go to, although it's $700. The Belltech 5519 looked like an alternative at $300, but Belltech states theirs is for lowered suspensions only (flipped springs?). I don't see why it wouldn't work on a standard set up, I like how it's anchored to the frame better than the Hellwig deal.
Has anyone installed the Belltech 5519???
The Belltech kit for lifted trucks is 9928
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
