I have a 2015 chevy silverado and the temperature sensor keeps going bad. I have replaced it 5 times in the last year and a half. This doesn't seem normal. Any ideas what may be causing it? I have replaced it with several different manufacturers and some times they last longer than others. Please help!!
I'm curious...have you replaced with a GM/AC Delco part?
The symptoms of a bad thermostat in these trucks - with the gauge pegging at the bottom - almost mirrors that of a faulty temperature sensor. I replaced the sensor first only to find that, while it did make the problem go away for a short time, it never really did fix the source and eventually it came back.
Have you only been replacing the sensor and not the thermostat? If so, I would bet money the thermostat is the root cause of your troubles. Please keep us posted!
  • 6 months later...
like me, might be bad luck. on my 2014 i replaced the thermostat 3 times before i got one that lasted. all 3 were from gm and the last one that has continued to work was motorad
Interesting. I had the opposite experience. OEM went bad after 7 years and I replaced it with a Motorad. That failed within a couple months and I installed another GM one but went with a 194⁰ one. It has worked just fine ever since.
I'm having same issue with my 2016 sierra. What is the fix for this problem. Does the thermostat need to be replaced as well as the temp senor?
Most likely neither your thermostat or temp sensor are bad. Most of the time it will be battery, alternator or ecu. Try removing your negative cable for 30secs then reconnecting. Power surges can cause the ecu to become confused and lock out the temp sensor and kick one the fan to prevent the engine from overheating. Removing the neg cable allows the ecu to reset. I’m no mechanic but it has been the case with my 2014 Chevy PU. I’d say it’s time to replace battery and see if that fixes your issue
I have 2017 6.0. I changed ECT Sensor and Thermostat. And still have engine light on An temp gauge still shows lowest temp.
  • 3 months later...
Above worked for me! Was just about to swap thr sensor when i read above and the battery reset fixed my issues. My issues were: check engine light, no AC, temp gauge all the way low on dash never going up, and the radiator fan blowing like crazy even when i shut it off. After battery reset all were immediately fixed:) 2015 silverado
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
