Big FYI on this kit.  It will NOT fit a stock height truck without installing the 2 inch Trail Boss kit FIRST.  It is a direct bolt-on if you already have that kit installed or have an AT4 or a Trail Boss.
The ZR2 Spec DSSV Shock System is designed and tuned specifically to deliver exceptional performance in a variety of scenarios - from technical rock crawling to tight two-track trails or hgh-speed desert running to daily driving. These 40mm Multimatic DSSV™ Shocks included in this system employ spool valve technology and offer increased precision for enhanced ride and handling performance both on- and off-road. Additionally, they provide up to a 2-inch increase in front suspension travel and up to a 1-inch increase in rear suspension travel. Enhancements from stock Silverado Trail Boss shocks include an 18mm diameter front rod and a 16mm rear rod to accommodate higher side load, advanced design seals to handle high shock temperatures, three separate spool valves to control damping and three connected chambers for fluid flow. Compatible with 2019+ Silverado Trail Boss models or vehicles equipped with the Performance 2-Inch Suspension Lift Kit (sold separately). Installation by an authorized dealer is recommended. The system includes complete front shock module assemblies, rear shocks, steel leaf springs and installation hardware.
47 minutes ago, jaxcam02 said:
What about the UCAs. Same as standard height or no?
It would use the existing UCAs no matter the model year.
Edited by newdude
What would it need from the TB/AT4?
Everything that would raise the truck is in this kit. Struts, rear springs, and blocks.
Edited by AJMBLAZER
Probably the CV axles for 4wd configurations and the lift blocks
Edited by jaxcam02
Yup. The only things I see missing are the rear leaf spring blocks and the longer cv shafts.
29 minutes ago, AJMBLAZER said:
The blocks are between the leaf springs and the lower of the two struts.
Just the leaf springs. The struts have the lift built in them.
I meant in the picture above. They are the two rectangles between the lower strut and the leaf springs.
Edited by AJMBLAZER
Gotcha! Yeah, looks to be them. Didn't even notice that.
  • Thanks 1
Meh, I'm good.  Recommended shock replacement is approximately every 50,000 miles.  I'd rather spend $240 every 50k than $2,400.
DSSV's are rebuildable and they are totally different than a normal gas charged shock/strut.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
