am considering buying a 2020 Sierra from an insurance company as a theft recovery. Is there a way to confirm the miles displayed on the electronic screen/odometer? Is it stored in the ECU or BCM or someplace to cross check?
The ins company is going to brand the title “not actual” as they have no idea what the thief may have done.
I would like to know the real miles
Edited by OldBob
  • OldBob changed the title to Odometer validation / fraud detection
you might consider taking the VIN to a dealership and see if they can produce service records.
I have service records until the theft. At that time someone changed the VIN plate and I believe changed the odometer reading. (Added about 20k miles) to agree with the mileage on the truck they took the vin from.
Ugh.
Why do you want a truck that was stolen, has a different VIN, questionable mileage, and who knows what else?
They more than likely drove it like they stole it because they stole it.
I would keep looking.
38 minutes ago, OldBob said:
Getting it way under value
If you like the price and are willing to deal with any problems buy it. Me, I would pass.
Nope. No way, no how. It would never find its way to my driveway. Same with a salvage titled vehicle.
I have 2 Jeeps I bought from Copart and made the needed repairs. One was replacing a rear frame member and a bumper. We have been driving it 8 yrs now. I bought another one from them in August with some minor cosmetic damage from a wind storm. Made the repairs and we love it and will likely have it many years. This Truck is the first theft vehicle so it is a little different animal.
I like having no car payments and we run our vehicles to about 225k before we get rid of them so the resale is not much of an issue and the cost per mile is low.
I also have a lot of.mechanic experience just not on the new computerized systems.
That all said, I just bought the wife a new Lincoln last month cuz that is what she wanted and it is nice to have new, warranty, etc. I admit.
being i am a mechanic and have all the diagnostic equipment , i would do it. can you test drive it first, and maybe have it scanned to see if there any miss match of the new vin in other modules.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
