Same here.  New module arrives at dealer Monday and should get it installed next week sometime.
Ok, just hitched up and towed for the first time…and even without solar I had the disconnects. Since I was just taking it in for a maintenance issue, I just turned the battery off and it solved the problem. But…Thursday we leave for a trip and since I have a 12v fridge I don’t really want to turn the battery off. Can’t get the fix done before then…what’s my best course of action? Any recommendations?
How far of a trip are you taking?   If you plug the rv in the day before and let the fridge and its contents get good and cold well before your trip, it will essentially act as a cooler when not powered on.   Or do you have a propane option?      I have another older travel trailer, the fridge only works on shore power.  I’ve camped with it several times by letting it all get cold for a few days before we left.  The day of the trip it will stay cold well over 9 hrs of driving until I get to the campground.
How hard is it to get to the wiring on your trailer?  I wired in a diode on my black 12v power feed line where it comes into the RV so that power can only flow from the truck TO the RV but not in reverse.  After doing that, I read 0v on the 12v pin of the trailer when it's sitting disconnected from the truck.  It shouldn't take more than 20 mins if you have decent access to the wiring.
Don’t have the propane option, but you make a good point - it’s a short trip, about 2hrs. So I think if I have everything good and cold I’ll be fine with the battery disconnect off. I can always throw a few reusable ice packs in if I’m really worried about it. I’m so used to the fridge running on the drive I missed the obvious that it’ll stay cold that long.
It’s our last trip this year, so I’ll have the dealer take care of the fix (hopefully) we’ll before I have to tow again.
Keep in mind that the battery quick disconnect only disconnects the 12v power going to the coach from the battery, but not from the truck to the battery or from the battery to the truck.  That was the first thing I tried when troubleshooting after reading the bulletin.  You’ll need to disconnect the negative lead from the battery to actually prevent the battery from back feeding. Or do as the others have suggested and wire in a diode.  Not sure what timeline you have but I couldn’t get one local and had to order one on Amazon.  If you can’t get one and wire it in before your trip, turning the battery disconnect will only kill power to your refrigerator but still give you the error message and turn off your brakes.
I was hoping someone would clear that up.  You are absolutely correct, the only way to turn the 12v fridge off is to shut it off with the knob inside the fridge or unhook the battery.  The battery disconnect does not turn your fridge off.
The battery quick disconnect will cut power to the 12v fridge and everything else inside the coach that runs on 12 volt ie. the interior lights, vent fans, water pump etc.    The point I was making is that the brake issue is due to the trailer battery back feeding into the truck.  The battery will still back feed into the truck even with the quick disconnect turned on because it only cuts the circuit to the internal 12v system of the rv. The running lights, brakes, and battery will still be powered and connected to the truck which wil cause the module to shutdown and give you brake issues.
If I’m understanding the issue that causes the problem correctly, can it be solved simply by letting the battery run down some before it’s time to hitch up and go? The fridge will put some drain on the battery as well on its own, and if it’s unplugged from shore power for, say, and hour or two, before travel…it shouldn’t be getting enough charge from the truck to be fully charged while on the drive? I thought I was understanding that the issue only occurred when the battery became fully charged and would back feed to the truck, but I’ll be the first to admit my battery/electrical knowledge is not my area of expertise. Oddly, the disconnect seemed to work today, but it was only about a 20 minute drive so that could’ve been a fluke.
edit: I also do NOT have solar, so the only charge the battery would get while driving is from the truck.
Edited by Salzette
I got the updated part installed last Thursday and removed the previously installed diode and did a 200+ mile drive with ZERO issues.  Looks like the updated brake controller finally fixed the issue.
For the sake of everyone reading, there were 2 solid solutions that worked without issue, and 1 potential solution.
Solution 1:  Installed Diode on the 12v charge wire (Black) from the Truck to trailer.  This prevented all back feeding and worked for long drives without issue.
Solution 2:  GM installed new Brake Controller.  Took them less then 1 hour for the install.  They did have to order the part which took a couple days.  Was fully covered by warranty.
Ideal Alternative Solution until you get GM installed updated Brake Controller:  I purchased the Curt Echo Mobile Bluetooth brake controller.  This is put inline with the trailer plug and bypasses the trucks brake controller.  You can control sensitivity and gain using a mobile app, and can even have a manual brake button on the phone.  I drove 2k+ miles using this setup.  I was very annoyed that I needed to use this adapter on a brand new 2024 3500 GMC, and lost the ability to control gain and manual braking with the in-truck controls, but it was better to have reliable brakes when I was going through a lot of mountains.
Potential Solution:  I attempted a drive with all 12v accessories turned on in the trailer while driving.  Fans, Lights, Fridge, etc.  This was an attempt to keep the charge on the batteries low enough that the back feeding would not occur.  It worked for about an hour before the 550watts of solar was charging faster then the usage.  This may be a viable solution for trailers with little or no solar.
Apparently it's different with different manufacturers.  On our Grand Design the battery disconnect does not turn power off to the fridge.
This is true of most units with an inverter that powers a residential fridge. I can disable both giggy boxes but still have to turn off the inverter if I want to shut down the fridge. It's a wonder trailer wiring works at all LOL.
Took my truck to the dealership on Wednesday. The service writer instantly acknowledged that they were tracking this issue. They ordered the replacement module, but don’t have any estimate on when they will get it. Told me that they hadn’t received any parts orders this week due to the strike.
I installed a switch to shut off my solar panels and that took care of my brake controller issue.  Unfortunately now my solar panel won’t charge my batteries when I’m towing.
    doylej24
    doylej24
  • Who's Online   3 Members, 0 Anonymous, 755 Guests (See full list)
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
