2019 GMC Sierra At4 5.3 70k Miles
Check engine light is on, Code is ambient air temp sensor.
AC is hot. 100 degrees out truck says "Ice possible, drive with care"
Take it to dealer, they want $2100 saying that the AC compressor is bad (I didnt go through with it)
I change the Ambient air temp sensor, clear the code.
Light goes off, AC blows 60 when the truck is moving. Blows warmer when the truck is sitting still.
Check engine light is back on. Same Code.
Air blows cool when moving at highway speeds warm when sitting still. outside air temp seems to be accurate.
What should I look at from here?
I'm no expert, and I'm not a fan of diagnosing vehicles over the phone (literally, since I'm view the forum that way), but it does seem the dealer may be correct about this one.
I’m not an expert on this. I would check the fans. Seems 60 while moving should be pretty good. Before electric fans vehicles would warm inside sitting still.
I would agree with this, if it cools while vehicle is in motion and not while stationary, that points to the radiator fans for me. Check to see if they come on when engine is hot. If they don't you should see engine temps rise while stationary as well.
The way I understand it. One should run whenever the AC is on. No matter the temperature.
Crap in fins of condenser (and/or) or rad reducing airlfow....
Anything installed in front of it?
On 6/22/2023 at 4:03 PM, Steve-2019 said:
Did you use an genuine GM part for the ambient sensor or aftermarket?
Yes sir, I got a GM one from Advanced. It has all the same markings as the old one.
On 6/23/2023 at 6:50 AM, silveradosid said:
is the a/c compressor making any strange noises, are the engine fans working . could be low on freon.
No strange noises that I can tell.. I hooked up a digital gauge that came with the Freon can. It showed that it was inside the window of a proper charge.
Can gauge cannot be trusted at all. It only reads the low side and they are not accurate. Need real high and low pressure gauges on it to get the full picture.
Dealer had real gauges on it, possibly the high side is low so that would indicate a weak compressor.
I’ve used the low can filler if my AC gets a little warm. Just used it on my avalanche with great results. I could and probably have a slow leak. If it last the season I’ll be tickled. Of course I know my truck and the AC still was cycling but quickly. Read the instructions it could bail you out. You have to have reasonable shade tree skills.
I’ve checked both rad fans. Both working and running.  Check engine light comes on when i crank up most of the time and the AC blows hot. Then cools down when I’m moving. Truck is a 2019, I hopped in my buddys truck last night and my AC, even at its coldest, is no where close to the temps his blows.
Look at the engine temp when sitting and when running. My wifes traverse temp sending sensor went out in her car. It said it was overheating on the temp gauge. When that happens the A/C will cut off to reduce the load on the engine that thinks it's overheating.
    LCH14
    LCH14
  • Who's Online   6 Members, 0 Anonymous, 985 Guests (See full list)
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
