I have a 17 Silverado 1500 z71 that I bought used with 89k miles on it. Around 93k or so, the transmission had to be replaced. It now has almost 100k on it. I know the transfer case fluid is supposed to be changed around this time.
My question is, what are the odds that they changed the transfer case fluid when they replaced the transmission? Or would it not be standard procedure to drop both at the same time. I've searched and have seen mixed opinions. The paperwork did not specify if it was done or not.
Well,
I think if the trans had been serviced BEFORE the owners manual recommends(I do more fluid changes) you wouldn't have needed to replace it. So I bet the transfer case was never touched.
I agree as far as the trans goes. It was a risk of buying a used vehicle. Fortunately I had an extended warranty that covered it, otherwise I would have been real upset.
Just trying to stay up to date with the maintenance now since I can only assume it wasn't fully taken care of before I bought it.
If it were me, I'd go ahead & change it as it only holds about a quart or 2. Easy job.
I would change it out. I would never trust the shop to be proactive, they likely did only what was necessary and used the lowest cost products in their repair. If you are of the believe all lubes are the same, then drive with confidence.
Edited by elcamino
Unlikely.  Transfer case was probably removed with the fluid in it.  Its only 2 quarts in there so not a whole lot of extra weight.
No more than ever 45k miles IMO for transfer case.  The book shows 97,500mi for "normal use" which is insane because the 2500/3500 chart shows every 45,000mi or for severe use every 22,500mi.
Yeah. Definitely going to change it. Just hoping no damage has been done. No idea how well it was maintained before I bought it.
For good measure, I would suggest replacing Front and rear diff as well as the transfer case. You will already be under the truck with the tools out, so what is an extra 30-45 min of time to have fresh fluid in everything?
  • Like 4
What’s the best fluid for front, rear differential and for transfer case? For 2015 Sierra 4x4
weight, brand etc..
I don’t get under the truck anymore so what’s a fair shop price for all?
thanks in advance
I use a synthetic 75W90 limited slip GL5 gear oil in front & rear.  Walmart Super tech works & is a good cost effective  GL5.
Transfer case takes Dexron 6. I use AC Delco  for it but any Dexron 6 meets the spec.
I used Mobil 1 Delvac 75W90 in my diffs because it doesn’t contain limited slip additive. The additive isn’t recommended for the G80 locker. It took 4qts 12oz for both diffs.
weight, brand etc..
thanks in advance
I used Amsoil Severe Gear 75W90 for the Front and rear Diffs in my 2014 and Amsoil Synthetic Trans oil for the transfer case.
Same here
    ncleg
    ncleg
  • Who's Online   1 Member, 1 Anonymous, 1,386 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
