Was going to do the DOD delete to my 6.2 Silverado when an acquaintance said it won't pass New Jersey inspection if I tune out the AFM. That is the only tuning change that will be made. Anybody else in New Jersey have this issue with inspections? I getting tired of the lifters failing. Finally out of warranty and it happened again. I have all the parts but now hesitant until I know I can proceed.
Maybe he was thinking about the Range AFM Disabler? I know in that if you pull the Range module just prior to you trying to do the emissions test, it will fail. It needs to be pulled well before the testing in order for all the sensors to be active and several start/stop as well as driving cycles. I found this out the hard way when I lived in Illinois. Once emissions testing done, it can be plugged right back in until next time.
As far as having the AFM disabled by a tune, I honestly don't know...
Edited by mikeyk101
I do have the Range disabler and I use it. And yes, it needs to be removed with enough time for the monitors to reset. I am talking about doing a full DOD delete: Cam, lifters, block plugs. The computer will need to be retuned to shut off AFM permanently. I just want to know if New Jersey State Inspection will detect the tuning change to the ECM. Since the warranty has expired, I can do the full delete now or if there are inspection issues, just remain stock.
If your state does the same thing as California, then you wouldn't pass. But if all your state does is make sure you have to check engine lights and can pass the readiness tests, you'd be just fine.
Just know that these new computers are very smart, you MUST have it tuned prior to you ever starting the truck again and all the codes MUST be disable to keep them away forever. If you start the truck with it not tuned and it tosses an error code for the AFM/DoD system it will likely be there in the background forever because once a permanent code is set it will never clear until the problem is fixed. But for you that problem will never be fixed because you removed all the parts.
If the codes are turned off before its started, the computer won't have a reason to toss a a code.
So you are saying that if the ECM is tuned before the DOD conversion and there is no codes before the work is done, then I should be ok? I was thinking of getting a DiabloSport and do an 87 octance tune with the AFM turned off. My truck is ticking due to a bad lifter on cylinder #4 with no codes yet. This is the 5th time I have had this problem. The dealer covered the first 4 times. All on cylinder #4, or at least the last 3 were on cylinder #4. That leads me to suspect the VLOM since its always the same cylinder. And no, the dealer didn't change the VLOM on all the other repairs. The problem now is that the VLOM is not in stock anywhere. Since the last dealer repair was about 5 months ago, I plan of replacing the one lifter, one head gasket, and 10 cylinder head bolts should cost about $125. That will get me past my inspection on 2/2024. I'll have two years till the next inspection. If it goes bad again, then the full DOD delete or sell the truck.
"Peoplez Republik of Illinoiz" here.............................same communism, different state................................my 2016 5.3 was rebuilt due to a non AFM lifter failure, and rebuilt without all the AFM BS.  Passed the Illinoiz OBD2 plug in inspection without issue last year.  Had issue 2 years prior when I was running the Range device....................didn't get enough engine cycles in without the Range for it to pass.
Update: Started disassembly today. Confirmed that one of the pushrods on cylinder #4 was bent. I replaced the pushrod and it opens and closes normally. The AFM lifters were replaced several months ago. Is it possible that I only have a bent pushrod? I have had and read so much about the AFM horrors that I am hoping I got off easy. So far I am only out my labor. I didn't dig into anything that will cost parts like coolant, fuel lines, or head gasket. I guess I can reassemble everything and see what happens. What does everyone think?
Correct, if you tune the computer prior to removing the stock camshaft and removing the VLOM and all that jazz, it should never set a light for any of those codes. You'd need a custom tune at that point to turn off every single code with that system. Not sure Diablo would have all that being that it's mostly pre-built "canned" tunes.
I use HP Tuners, so that is how I go about turning off codes prior to work being done.
Update: I replaced the bent pushrod and reassembled. Restarted and tapping still there. Bitting the bullet and gonna replace the lifters. Once I get it through inspection, I'll tear it down again and do the DOD AFM delete. Was hoping to get off easy but no such luck. Looks like another $250 to replace the lifters. Also, it looks like the dealer stripped an exhaust manifold bolt. Easy to fix once the head is off. Really sucks that VLOMs are nowhere to be found. I think thats my issue.
Update #2: I was able to obtain a new VLOM at a decent price of $220. Disassembled and replace the four AFM lifters on passenger side, installed VLOM and started reassembly. Torquing the 7th head bolt to the final degrees and it let loose. I guess having the head removed 4 times was the limit. Now I have to start over. I just purchased the NS300L head bolt rethread kit and will do all 10 head bolt holes. Youtube videos look straiaght forward on how to do the job. Now another set of head bolts and head gasket. I can just imagine what this would have cost at a dealer.
I found this video on youtube. He shows how the VLOM will fail causing the AFM lifters to fail. I did this test and yes, the solenoids leaked just like in the video.
In that case, DFM was deleted in the software by GM. Nobody has come forward with any answers that if I delete the AFM via tuner will it cause any issues with New Jersey OBD2 inspection. Others around the country have commented but nobody from New Jersey has confirmed or deny any issues.
Western NY resident here.  On my last truck I had AFM turned off via HP Tuners.  Never had one ounce of trouble plugging in for NYS OBD emissions inspection, passed every time.  Not sure if I would have had issues in the NY metropolitan area as the rules are enhanced down there but the OBD side of things it would pass there.
Edited by newdude
Probably because the 2019"s are only due for inspection this year. My 2021 inspection sticker is good until 2026.
But I think you answered your own question - the DFM was deleted in the software.
Edited by Diamond817
Do you happen to know anyone that does emissions testing in Jersey? If so, you could ask them and see what they say. The only state that I've heard of that goes in and actually looks for a tune is California. If Jersey doesn't do this, I'd think you'd be okay.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
