I had a Dee Zee bed mat in my 1500 and loved it. I have been waiting on them to become available off of backorder since last May.
What are you guys using if you are?
I have the GMC accessories rubber bed mat in my 3500hd long bed. It’s 3/8 thick and fits perfectly. I bought it through my Chevy dealer (gives better prices on parts than the GMC dealer next door) for about $160. I bought it primarily to keep my camper from shifting, but it’s also nice when the camper is unloaded.
I too had a Dee Zee in my 2018 1500. Great mat and I wanted to get the same for my 2500. I didn’t see one on the Dee Zee site so I’m not sure what other sites are showing as “backordered”. I used my “Chevy Rewards’ points and bought one from a Dealer in Georgia. Does fit perfect, has a bow tie and is black but it is not as thick and heavy as the Dee Zee mat was.
Go to tractor supply or fleet farm or equivalent store and pick up a 5/8” thick 4x6 barn stall mat. They are 40 bucks and are meant for horses to walk on. They will outlast any truck and are cheap but extremely durable. About 100lbs of black rubber.
Thanks for the replies.
I checked the GM internet parts sites and they average $230-$260 shipped. For the quality of the DZ (part number DZ87022) I think I'll wait it out a little longer and hope that they become available.
Summer of 2021 when I bought mine Dee Zee did not have ones for the long bed - just the standard hd bed.
It might be worth calling a few local dealers to get a price on the GM mat. Mine was quite a bit cheaper from the dealer than buying it from gmpartsdirect and similar when shipping was added. I suspect it was because they could get it from the distribution center as part of a large shipped load so the shipping cost was very low.  I had to wait about a week for it to come in their weekly stock parts delivery.
I only paid 150 for my longbed gm one, used rewards to pay. Delivered to a local dealer.
I use the Chevrolet accessories rubber mat. Bought it with the My Chevrolet Rewards.
Works great and nothing slides around in the bed.
Edited by gregus73
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
