Got 2 emails today for my HD's for a recall for the tailgates dropping. I logged in the the MyGMC app for specific's and it shows it includes Canadians 1500's.
I'm betting USA 1500's will be included before it's over with...
Good to know. Mine just unlatched by itself after returning home from a carwash (probable  water intrusion). 2023 Trail Boss made in Silao MX.
Interesting. Friend of mine had a 2020 Sierra 1500 that would unlatch while driving. Dealer could never find anything. He got rid of it. Same cause maybe? I will keep an eye on my 23 Sierra 1500.
1 hour ago, ExYukon said:
Does this apply to multiPro/Flex tailgates or just the traditional ones?
Power unlatching. Any with the button not the traditional handle.
My 2021 tailgate power switch within the rear "handle" has indeed failed. No opening of tailgate except by dash switch or remote now.
Separate actual trips to two GM dealer's parts counters has found no replacement electric tail gate switch available and zero NOS switches available any where in Canada.
Inquiring minds not giving up, a call to a "jobber" parts outlet concludes the black plastic handle/housing is available for $70 but no electrical giblets are sold through them, including any kind of electrical latch switch.
I'm watching this one, mine hasn't unlatched it's self but I have had a few times where pushing the button to open hasn't worked and I had to use the remote to open it. Just turned over 3000 miles.
A call to your dealer service department will let you know if your truck is part of the recall. I was in for an oil change and tire rotation last week and asked the service writer to check. Mine is not in the recall.
Hopefully that up-graded tail gate switch is soon to be released!?
Now when I approach the truck with fob, that tailgate latch locks and unlocks like mad! No doubt the next issue will be a tail gate lock system mechanical failure due to being worn out!
Chances are I'm going to have to duck tape this tailgate shut?
Good times.....
"Duct" tape did OK except at freeway speed. Therefore "duct" tape has been cancelled. i removed the inner tailgate panel and disconnected the bogus switches' connector within the tailgate. Not a difficult job to isolate.
A quick call to my local GM dealer parts concluded no release date yet for the upgraded switch.
Put the panel back on the tail gate. Back to the freeway, without "duct" tape.
Party on.
dealer called me yesterday about a recall for programming of the headlights. We also discussed the open recall on this truck for the tailgate issue.
Seems there is still not a solution --- but the dealer is a method to disable the tailgate buttons so thay can no longer send the request to open to the BCM. (presumably they do the same as @Delta Tango mentioned and disconnect the switch)
Tailgate will still open using the FOB or the button inside truck.
For some this will be a reasonable temporary solution.
I have a 22 LTD with the power release tailgate.  Never had any issues with mine and this truck lives outside 24/7. I checked my VIN on the Chevy Recall lookup and it says there are no open recalls for my truck.
Still gonna keep an eye on it…
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
